How do I skip attributes that are null or blank?
3084
02-26-2019 10:06 AM
JordanMiller4
Is there a way to check if a field is blank or null and if it's not continue the script? I can't quite get the function to work unless I'm missing something. Thanks
 if row[0] != "": # if field is not blank or null then...
import sys
import os
import arcpy
sdeconnection = "Database Connections/SDE.sde"
fc = 'Database Connections/SDE.sde/NEO.SDE.Inspections/NEO.SDE.ACInspectionSites2019'
fields = ["INSPECTEDBY", "INSPECTIONSTATUS"]
try:
    edit = arcpy.da.Editor(sdeconnection)
    print "edit created"
    edit.startEditing()
    print "edit started"
    edit.startOperation()
    print "operation started"
    # Perform edits
    with arcpy.da.UpdateCursor(fc, fields) as cursor:
        # For each row, evaluate the WELL_YIELD value (index position
        # of 0), and update WELL_CLASS (index position of 1)
        for row in cursor:
                row[1] = "Completed Inspection"
                # Update the cursor with the updated list
                cursor.updateRow(row)
    edit.stopOperation()
    print "operation stopped"
    edit.stopEditing(True)  ## Stop the edit session with True to save the changes
    print "edit stopped"
except Exception as err:
    print err
    if 'edit' in locals():
        if edit.isEditing:
            print "operation stopped in except"
            edit.stopEditing(False)  ## Stop the edit session with False to abandon the changes
            print "edit stopped in except"
finally:
    # Cleanup
    arcpy.ClearWorkspaceCache_management()
Tags (1)
JoshuaBixby
MVP Esteemed Contributor
Instead of giving you a specific answer, I encourage you to read /blogs/dan_patterson/2016/11/03/before-i-forget-18-those-pesky-null-things .  Building an understanding of Boolean evaluations of different data types is critical to answering this and similar questions.
DanPatterson_Retired
I should update with additions to other 'whitespace' problems I have found since I wrote it.
But in short... generally don't try an equality check or its negation.
If you have more than one possible 'goof' in the data preparation try 'in'
if blah not in (None, "", " "):
    then do something useful
some of the pitfalls are in the other document, but as you move toward python 3, there will be other traps you will have to be aware of
PavanYadav
One way to do what you're looking for.
if row[0]:
or :
if len(row[0])
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
