How do I list the Schema name of an Element in an SDE database (Newbie Q)
1846
07-14-2013 02:59 PM
PeteSmyth
Hi All
I am new to all this, so thanks for your patience:D.
I used the code below to list the Name and data type of an element in an SDE database.
What I really need to do now is identify and write the Schema(element owner) for each element as well, as I have a number of Schemas in the Database.
import arcpy
# Create a Describe object
desc = arcpy.Describe(r"Database Connections\SDCM_SIS in PRD as 044231 DC.sde")
# Print some Describe Object properties
for child in desc.children:
    print "\t%s,%s" % (child.name,child.dataType)
ArkadiuszMatoszka
I think you should already have schema name in child.name string.
Your child name should be something like:
SHEMA.FEATURE_CLASS_NAME
So all you need to do is split child.name on dot and get first element of the list.
import arcpy
    print "\tSchema: %s, Table: %s, DataType: %s " % (child.name.split('.')[0], child.name.split('.')[1], child.dataType)
Regards
Arek
