How do I get layers' IDs using python?
15188
24
01-04-2016 12:56 AM
DavidePavia
Hello everyone and thanks in advance for the attention here is my problem..
..working in an ArcMap session, I've checked the option to get an ID for each of the layers in my document, so anyone has it.
Now, what I need is a way to get these values within a python script (to copy that automatically in a table): there's no such information in the layer's properties reached by a describe, nor from the .mapping module..
Thanks, and have a good day!
Davide
FrédéricPRALLY
Hi Davide,
I think I should recompile the tool under windows server 2012 R2 but I have not this OS at home. Sorry ...
Otherwise I modified the tool “Get layer ID for all layers in mxd” to managed group layer and multiple data frame on tool “Get layer ID for all layers in mxd”.
See gp result message :
Working on mxd E:\01_client\layerIDS.mxd
Dataframe: Layers01
LayerName | LayerID
prefecture | 10
departements | 33
New Group Layer | 35
     dep1 | 36
     Sub Group Layer | 39
           dep3 | 36
           dep4 | 37
     dep2 | 37
Dataframe: Layers02
LayerName | LayerID
prefecture | 2
departements | 1
New Group Layer | 0
     dep1 | 5
     dep2 | 6
Fred
DavidePavia
Good afternoon Frédéric,
could I please contact you privately?
I've tried to send a private message here in Geonet, but I guess that we need to be "Friend"..
Thank you very much, have a good evening
Davide
DavidePavia
Dan, as you'll read below I succeed in the installation by unlocking the .zip file as Fred told thank you anyway for the precious help!!
TobiasFimpel
 Davidepaviaarcgis, fprallyesrifrance-fr-esridist, and others: do you know if any alternatives have been made available by Esri or others since this thread started? I am hoping to run this on a more recent Windows OS and more recent version of ArcMap. Thank you.
RichardHartley2
I managed to run the "Get layer ID for all layers in mxd" tool using ArcMap 10.5.1 on Windows 10 using ModelBuilder (as described in the tool documentation). However, it does not seem to run when running the tool from ArcCatalog, as I receive 'ERROR 000816: The tool is not valid'.
