How Can I Close an mxd using arcpy script
9501
6
08-25-2012 09:15 PM
OLANIYANOLAKUNLE
How Can I Close an mxd using arcpy script. Thanks
RichardFairhurst
MVP Alum
Python is still more of a geoprocessing oriented language is GIS than a full blown windows application management language.  The arcpy options only let you save or saveacopy of the document, but there is no close option.  I haven't seen any native Python that manages open Wndows applications.  Perhaps there is an extension someone has written that I am unaware of, but the python.org help does not come up with anything I can find.
I think you are expecting more out of Python than ESRI has tried to support at this time.
BruceBacia
This will kill ArcMap itself.
import os
os.system("TASKKILL /F /IM ArcMap.exe")
BruceBacia
Also you can open a specific mxd like this:
import os
os.startfile("Your MXD Path")
RichardFairhurst
MVP Alum
import os
I stand corrected.
OLANIYANOLAKUNLE
Thanks! I got it
EdMorris
Hi
I have just blogged on this >>
Using Python to close an ArcMap map document down | Spatial Needs....
This will show you how to close an MXD down by name....
thanks ed
