How auto increment a field using a range?
1919
03-04-2017 07:40 AM
MaziziJama
I have an empty table with an integer type field, let us call it "field1"
I want to populate field1 with numbers ranging from 1-5, so that my table looks like this
OBJECTID      FIELD1
1                        1
2                        2
3                        3
4                        4
5                        5
I have come across this example - How To: Create sequential numbers in a field using Python in the Field Calculator
But do not know how to adapt it to fit my need.
Regards,
JoshuaBixby
MVP Esteemed Contributor
Similar question to In Field Calculator 1 To 9 Loop Numbers‌.
Pre-Logic Script Code:
from itertools import cycle
rot = cycle(range(1,6))
def next_number():
    return next(rot)
Value:
next_number()
