Hide Unselected Features
2439
6
01-20-2013 04:11 PM
babakkasraei
I have used the following codes to delete the selected features:
if int(arcpy.GetCount_management(layer).getOutput(0)) > 0:
       arcpy.DeleteFeatures_management(layer)
I have two questions
1- What if I want to deleted unselected features? Can I use the following syntax?
 if int(arcpy.GetCount_management(layer).getOutput(0)) = 0:
2- I don't want to delete the features. I only want to hide them. What syntax should I use instead of
3- How about if I want to show them again. What syntax must be used?
I will appreciate if anybody help me.
Best Regards
Babak
KimOllivier
Honored Contributor
The selected features definition is part of the layer properties.
All you are doing is counting the number selected before you delete them.
Selected features from a featureclass can be defined by a definition expression and a selection set that is arbitrary
There is an arcpy.Describe() property FIDSet that will enable you to get a list of selected FID's that you can build into a set
then invert the set and make a new layer definition, but it is a bit geeky. You  have to manipulate a list of FIDs and use an SQL query with a list.
babakkasraei
Thank you Kim I will work on it.
Best Regards
babakkasraei
Using the describe function will be something like this.
# describe the feature layer to access the the selected set
desc = arcpy.Describe(layer)
# FIDSet will contain the selected features
selectedFids = desc.FIDSet
# If there are selectedFids (a selection set), write them to a new feature
# class in the current workspace.
if len(selectedFids) > 0:
 do something
Please let me know how you want to invert it now.
MathewCoyle
Honored Contributor
 do something
You'll have to create a layer object to reference the definitionQuery parameter if you haven't already. Then something like this.
oidField = desc.OIDFieldName
queryList = selectedFids.replace(';', ',')
oidDelim = arcpy.AddFieldDelimiters(layer, oidField)
layerObject.definitionQuery = '{0} in ({1})'.format(oidDelim, queryList)
arcpy.RefreshActiveView()
babakkasraei
So It will finally become something like this.
    # Here I create a new FC from my selected FIDS
 arcpy.CopyFeatures_management(layer,"AnewFC")
layerObject.definitionQuery = '{0} not in ({1})'.format(oidDelim, queryList)
It is amazing Thank you. However, the last lines is a little bit confusing for me. Would you please add a little descriptions to them.
For instance I still don't know how it happens to hide the unselected features.
I appreciate your help.
babakkasraei
Hi Kim
I have created the following codes for my "Hide Unselected Features" button function in My Tkinter as you instructed me, but they don't do anything.
Would you have a look on them. Why don't they work?
def button3Click(self, selection):
        index = self.listbox.curselection()
        label = self.listbox.get(index)
        # Local variables:
        layer = label
ln these codes layer is an object layer which is chosen from a listbox.
Thank you for your help for doing my first button. It was a great help.
Please help me for this button too.
Best Regards
