i'm trying to clone a Survey from one org to another, ive tried the guides here:
Clone surveys from one organization to another | ArcGIS Survey123
Survey123-tools/Clone_Surveys at main · Esri/Survey123-tools · GitHub
but it never actually copies the survey
i have also tried the "ArcGIS Assistant "
the survey isnt that complicated its a point feature layer and 10 related tables, each has no more than 10,000 records (most have 1000 to 5000) including attachments
has anyone managed to clone their survey?
Stu
code being ran:
# Create new group in the target environment
#shared_group = target.groups.create(title=group.title, tags=group.tags)
# Clone source items to the target environment
for form_item in sourceForms:
# Obtain the feature service associated with the survey
related_items = form_item.related_items('Survey2Service','forward')
# Obtain the additional items that have a relationship with the survey
additional_items = form_item.related_items('Survey2Data','forward')
all_items = [form_item] + related_items + additional_items
print("Source items: ", *all_items, sep="\n")
# Create new folder according to survey name
title = form_item.title.replace(" ", "_")
folderName = "Survey-" + title
target.content.create_folder(folderName)
# Clone all items to the new folder in target environment
cloned_items = target.content.clone_items(items=all_items, folder=folderName, copy_data=False)
# Check the feature count in cloned feature layer. Feature count should 0 because existing data is not copied
try:
print("Result feature count: ", cloned_items[0].layers[0].query(where='1=1', return_count_only=True))
except:
print("error with counts")
for item in cloned_items:
if item.type == 'Form':
# Update the form item to ensure all resources are rebuilt
downloaded_item = item.download(file_name=item.id+'.zip')
item.update({}, downloaded_item)
os.remove(downloaded_item)
# Share the form item to the group
item.update(item_properties={'tags':'Valve Survey blank'})
#item.share(groups=shared_group.id)
# Share source feature service to group
source_fs = item.related_items('Survey2Service','forward')[0]
source_fs.update(item_properties={'tags':'Valve Survey blank'})
#source_fs.share(groups=shared_group.id)
else:
pass
Error:
KeyError Traceback (most recent call last)
/opt/conda/lib/python3.11/site-packages/arcgis/_impl/common/_clone.py in update_form(self, target, new_item, clone_mapping)
5406 if related_item in service_related:
-> 5407 new_id = clone_mapping["Services"][related_item["url"]]["id"]
5408 feature_service = target.content.get(new_id)
KeyError: 'https://services3.arcgis.com/Ee____hzcB/arcgis/rest/services/service_8a209f____e6cf8/FeatureServer'
During handling of the above exception, another exception occurred:
Exception Traceback (most recent call last)
/opt/conda/lib/python3.11/site-packages/arcgis/_impl/common/_clone.py in clone(self)
5162 original_item = self.info
-> 5163 self.update_form(self.target, new_item, self._clone_mapping)
5164 else:
5446 except Exception as ex:
-> 5447 raise Exception(
5448 "Failed to update {0} {1}: {2}".format(
Exception: Failed to update Form Valve Survey App V2 Blank: 'https://services3.arcgis.com/Ee____hzcB/arcgis/rest/services/service_8a209f____e6cf8/FeatureServer'
_ItemCreateException Traceback (most recent call last)
/tmp/ipykernel_36/3848405123.py in <cell line: 0>()
18
19 # Clone all items to the new folder in target environment
---> 20 cloned_items = target.content.clone_items(items=all_items, folder=folderName, copy_data=False)
21
22 # Check the feature count in cloned feature layer. Feature count should 0 because existing data is not copied
/opt/conda/lib/python3.11/site-packages/arcgis/gis/__init__.py in clone_items(self, items, folder, item_extent, use_org_basemap, copy_data, copy_global_ids, search_existing_items, item_mapping, group_mapping, owner, preserve_item_id, **kwargs)
8758 wab_code_attach=kwargs.pop("copy_code_attachment", True),
8759 )
-> 8760 return deep_cloner.clone()
8761
8762 def bulk_update(
1326 > 0
1327 ):
-> 1328 return self._clone_synchronous()
1329 # elif len([node for node in self._graph.values() if isinstance(node, _StoryMapDefinition)]) > 0:
1330 # return self._clone_synchronous()
/opt/conda/lib/python3.11/site-packages/arcgis/_impl/common/_clone.py in _clone_synchronous(self)
1219 if item:
1220 item.delete()
-> 1221 raise ex
1222
1223 return [i for i in self._get_created_items() if isinstance(i, arcgis.gis.Item)]
1201 for node in leaf_nodes:
1202 try:
-> 1203 node.clone()
1204 except _ItemCreateException as ex:
1205 exceptions.append(ex)
5175
5176 except Exception as ex:
-> 5177 raise _ItemCreateException(
5178 "Failed to create {0} {1}: {2}".format(
5179 original_item["type"], original_item["title"], str(ex)
_ItemCreateException: ("Failed to create Form Valve Survey App V2 Blank: Failed to update Form Valve Survey App V2 Blank: 'https://services3.arcgis.com/Ee____hzcB/arcgis/rest/services/service_8a209f____e6cf8/FeatureServer'", <Item title:"Valve Survey App V2 Blank" type:Form owner:[email protected]_CadentFSM>)
