Help GIS Tutorial for Python Scripting ex 2.3
4783
01-14-2015 09:58 AM
ChantellKrider
I recently purchased David Allen's GIS tutorial and I'm stuck on exercise 2.3. The objective is to buffer multiple paths with variable buffer distances based on the length of the path -step 7 (I'm stuck here). The exercise uses a search cursor to go through each path and buffer accordingly. The data are available with the book here. I know the buffer line is incorrect, it needs to call fcName and wellBuffDist.
It would be helpful to see the full script...if anyone has already completed this exercise. Thanks.
try:
  import arcpy
  from arcpy import env
  env.workspace = r"C:\EsriPress\GISTPython\Data\City of Oleander.gdb\Well_Data"
  env.overwriteOutput = True
  fcName = "BC_South_3H_Path"
  wellCursor = arcpy.da.SearchCursor(fcName,["Shape_Length"])
  for row in wellCursor:
    drillLength = row[0]
  def wellBuffDist(drillLenght, wellBuffDist):
    if drillLenght < 3000:
      wellBuffDist = 75
    elif drillLenght >= 3000 and drillLenght < 4000:
      wellBuffDist = 175
    else:
      wellBuffDist = 300
# Replace a layer/table view name with a path to a dataset (which can be a layer file) or create the layer/table view within the script
# The following inputs are layers or table views: "BC_South_3H_Path"
  arcpy.Buffer_analysis(in_features="BC_South_3H_Path",out_feature_class="C:/EsriPress/GISTPython/MyExercises/Scratch/Temporary Storage.gdb/SelectionBuffer",buffer_distance_or_field="300 feet",line_side="FULL",line_end_type="ROUND",dissolve_option="NONE",dissolve_field="#")
  print "great job!"
except:
  print "do over"
DallasShearer
this should work...
try:
  import arcpy
  def wellBuffDist(drillLenght):
      BuffDist = 75
      BuffDist = 175
    else:
      BuffDist = 300
    return str(BuffDist) + " feet"
    wBuffDist = wellBuffDist(row[0])
    arcpy.Buffer_analysis(in_features=fcName, out_feature_class="C:/EsriPress/GISTPython/MyExercises/Scratch/Temporary Storage.gdb/SelectionBuffer", buffer_distance_or_field=wBuffDist, line_side="FULL", line_end_type="ROUND", dissolve_option="NONE", dissolve_field="#")
  print "great job!"
except:
  print "do over"
ChantellKrider
Dallas-
Wow! thank you sooo much. I really appreciate your response. I did run the code you suggested and it almost works. I commented bits out until I discovered the source of the error. It gets hung up in the buffer statement where it calls the wBuffDist. I'll do a little more work to try and figure it out.
Thanks again!
XanderBakker
Esri Esteemed Contributor
Hi Chantell Krider‌,
When you post code, could you please use the syntax highlighting?
Posting Code blocks in the new GeoNet
In case Dallas answer was helpful you can mark it as Helpfull (below the post you'll find "Helpful Yes | No").
In case Dallas answered your question you can mark his post using the button "Correct Answer".
Kind regards, Xander
ChantellKrider
Okay. Thanks. I'm new to this. Thanks for the tip.
