Hello everyone, I am getting error while printing the "INSTALLATIONDATE" & "MEASUREDLENGTH". MEASUREDLENGTH is having double datatype & INSTALLATIONDATE is having date data type. Could you please check my complete code?
Below is my code:
import arcpy
from datetime import datetime
arcpy.env.workspace = "D:\Pipe\map.gdb"
featureClass_1 = "P_Pipes"
Table_Pipe = "Pipe_Risk"
fieldNames_1 = [ "Material" , "OPERATINGPRESSURE" , "MEASUREDLENGTH" , "INSTALLATIONDATE", "Risk_Score"]
fieldNames = ["Material" , "OPERATINGPRESSURE" , "MEASUREDLENGTHLOWERLIMIT" ,"MEASUREDLENGTHUPPERLIMIT" , "INSTALLATIONDATELOWERLIMIT" , "INSTALLATIONDATEUPPERLIMIT" , "OVERALLRISKSCORE"] #Lookup table
def Pipe_Risk_Score(Material, OPERATINGPRESSURE, MEASUREDLENGTH, INSTALLATIONDATE): #Material_Out_fields = ["Material" , "OVERALLRISKSCORE"]
Material_where_Clause = "Material = " + Material
Table_Pipe_Cursor = arcpy.da.SearchCursor(Table_Pipe, ["Material" , "OVERALLRISKSCORE"],Material_where_Clause)
for row in Table_Pipe_Cursor:
Material_Risk_Score = row[1]
print Material_Risk_Score OP_Out_fields = ["OPERATINGPRESSURE" , "OVERALLRISKSCORE"]
OP_where_Clause = "OPERATINGPRESSURE = " + OPERATINGPRESSURE
Table_Pipe_Cursor = arcpy.da.SearchCursor(Table_Pipe, OP_Out_fields, OP_where_Clause)
OPERATINGPRESSURE_Risk_Score = row[1]
print (OPERATINGPRESSURE_Risk_Score) ML_Out_fields = ["MEASUREDLENGTHLOWERLIMIT" ,"MEASUREDLENGTHUPPERLIMIT" , "OVERALLRISKSCORE"]
ML_where_Clause = "MEASUREDLENGTHLOWERLIMIT <= " + MEASUREDLENGTH + " and MEASUREDLENGTHUPPERLIMIT >= " + MEASUREDLENGTH
print ML_where_Clause
#Not giving me output after Print (ML_where_Clause)
Table_Pipe_Cursor = arcpy.da.SearchCursor(Table_Pipe, ML_Out_fields, ML_where_Clause)
MEASUREDLENGTH_Risk_Score = row[2]
print MEASUREDLENGTH_Risk_Score #No output of this print function INSTALLATIONDATE = datetime.strptime("1935-01-01 " ,"%Y-%m-%d") #"01/01/2035 00:00:00")
ID_Out_fields = ["INSTALLATIONDATELOWERLIMIT" , "INSTALLATIONDATEUPPERLIMIT" , "OVERALLRISKSCORE"]
ID_where_Clause = "INSTALLATIONDATELOWERLIMIT <= datetime(1935-01-01 ) and INSTALLATIONDATEUPPERLIMIT >= datetime(2035-01-01 )"
Table_Pipe_Cursor = arcpy.da.SearchCursor(Table_Pipe, ID_Out_fields, ID_where_Clause)
ID_Risk_Score = row[2]
print (ID_Risk_Score) # Error: Unconverted data remains:#Final_Risk_Score = (Material_Risk_Score + OP_Risk_Score + ML_Risk_Score + ID_Risk_Score)/4
#Pipe_Risk_Score(Material , OPERATINGPRESSURE , MEASUREDLENGTH , INSTALLATIONDATE) # Showing me Name error using this line without quotes
Pipe_Risk_Score("Material" , "OPERATINGPRESSURE" , "MEASUREDLENGTH", "INSTALLATIONDATE")
For your text based where clauses, you'll need single quotes around the text value. For example:
Material_where_Clause = "Material = '{}'".format(Material)
The date expressions are failing because you have a trailing space.
INSTALLATIONDATE = datetime.strptime("1935-01-01", "%Y-%m-%d")
Sir, See if i have ranges for the date like from 1935-2035 so below statement is correct? Actually while printing the below statement it's only giving me the upper value i.e., ('2035-01-01', '%Y-%m-%d')
INSTALLATIONDATE = datetime.strptime("1935-01-01" , "%Y-%m-%d") and ("2035-01-01" , "%Y-%m-%d")
Also what will be the "Where Clause" for the same as per you?
The <= and >= you used in your original code should work for querying a date range. Just get rid of all trailing spaces.
Sir, so what will be my where clause? Could you please tell?
I should have asked where your data is because that will change the syntax a little.
Re: Using where clause to query date ranges in Arc... - Esri Community
For example, a file geodatabase where clause with date would be
ID_where_Clause = "INSTALLATIONDATELOWERLIMIT >= date '1935-01-01' AND INSTALLATIONDATEUPPERLIMIT <= date '2035-01-01'"
Sir, I'm using file gdb. But the code gives me error. Please get me rid out of this problem.
Below is the error statement in bold:
RuntimeError: An invalid SQL statement was used. [SELECT INSTALLATIONDATELOWERLIMIT, INSTALLATIONDATEUPPERLIMIT, OVERALLRISKSCORE, OBJECTID FROM Gas_Valve_Risk WHERE INSTALLATIONDATELOWERLIMIT <= datetime('1935-01-01') and INSTALLATIONDATEUPPERLIMIT >= datetime('2035-01-01')]
You're using the wrong syntax for a file geodatabase.
SQL reference for query expressions used in ArcGIS—ArcGIS Pro | Documentation
Try
If that doesn't work, try adding the time component like
ID_where_Clause = "INSTALLATIONDATELOWERLIMIT >= date '1935-01-01 00:00:00' AND INSTALLATIONDATEUPPERLIMIT <= date '2035-01-01 00:00:00'"
