Get SSL details thorugh portalpy
5638
11
12-14-2016 08:16 AM
ADITYAKUMAR1
Hi team,
  I am working on portal.py. I am trying to get the details of SSL certficates which the portal is using.
 I have tried with some code but nothing is working. Any suggestion on this will be helpful.
import sys
sys.path.append('..')
import portalpy
import csv
import ssl, socket
portalUrl           = "https://xxx-xxx.xx.xx.com:7443/arcgis"
portalAdminUser     = "xxxx"
portalAdminPassword = "xxxx"
portal = portalpy.Portal(portalUrl, portalAdminUser,portalAdminPassword)
users = portal.search_users('(role:account_admin OR role:account_publisher  OR role:account_user)')
activeUser = portal.logged_in_user()
print activeUser['email']
ctx = ssl.create_default_context()
s = ctx.wrap_socket(socket.socket(),server_hostname='http://xxx-xxx.xxxx.com/arcgis/home/')
s.connect((portal, 443))
cert = s.getpeercert()
print cert
Aditya Kumar
JoshuaBixby
MVP Esteemed Contributor
If you are using 2.7.9 or later, the examples already provided will get you the information you want.  The cert information is returned as a dictionary containing a mix of tuple, Unicode, string, and long; so you just need to explore the structure of that dictionary to know which keys and values to work with.
Using GeoNet as an example:
>>> import ssl, socket
>>> hostname = 'geonet.esri.com'
>>> s = ctx.wrap_socket(socket.socket(), server_hostname=hostname)
>>> s.connect((hostname, 443))
>>> props = []
>>> props.append(('Valid from', cert['notBefore']))
>>> props.append(('Valid to', cert['notAfter']))
>>> props.append(('Serial number', cert['serialNumber']))
>>> for name,value in props:
...     print "{:<20}{}".format(name, value)
Valid from          Sep 30 00:00:00 2016 GMT
Valid to            Nov 29 23:59:59 2017 GMT
Serial number       616FD344BDA2F974F351E1F18CFE8881
RebeccaStrauch__GISP
Joshua,
I was able to run this in the Pro python window, but had to add ( ) around the print string.  Based on things I've read on one of Dan's /blogs/dan_patterson/2016/05/09/the-links?sr=search&searchId=a1012d53-da1f-4df7-b109-573165a00e62&se...‌ blogs, that is a requirement for the 3.x python flavors.
So, yours is the correct answer, but here it is with the change
import ssl, socket
props = []
     print ("{:<20}{}".format(name, value))
I was able to successfully run this against my own hostname.  thanks.
