Get a list of installed python packages
7090
12-16-2019 08:26 AM
JoeBorgione
I'm going to bite the bullet perform the incremental upgrade from ArcGIS Pro 2.4.0 to 2.4.2.  In a python command window, I can run the pip list command and get the list and/or redirect that command to a file:
pip list
pip list > C:\temp\pip.txt
Is there a python command that I can run in a spyder console get the same result?  I haven't found anything in my google travels...
That should just about do it....
DanPatterson_Retired
(....) C:\...your install path...\bin\Python\envs\...your environment ...>conda list
# packages in environment at ...
alabaster                 0.7.12                     py_0
arcgis                    1.7.0                  py36_863    esri
arcgispro                 2.5                           0    esri
argh                      0.26.2                   py36_0
asn1crypto                1.2.0                    py36_0
astroid                   2.3.3                    py36_0
atomicwrites              1.3.0                    py36_1
attrs                     19.1.0                   py36_1
autopep8                  1.4.4                      py_0
babel                     2.7.0                      py_0
backcall                  0.1.0                    py36_0
bcrypt                    3.1.7            py36he774522_0
blas                      1.0                         mkl
bleach                    3.1.0                      py_0
ca-certificates           2019.11.27                    0
certifi                   2019.11.28               py36_0
cffi                      1.12.3           py36h7a1dbc1_0
cftime                    1.0.0b1          py36h452e1ab_0
chardet                   3.0.4                 py36_1003
...huge snip
Then I do a big select all (right-click the top white margin, edit, select all)
then paste it into notepad++
You can also direct it to a file
conda env export > c:/temp/some.yaml
If you want to recreate an environment
argh                      0.26.2                   py36_0
attrs                     19.1.0                   py36_1
autopep8                  1.4.4                      py_0
babel                     2.7.0                      py_0
blas                      1.0                         mkl
bleach                    3.1.0                      py_0
...huge snip
PS  If you are using a conda environment, don't use pip unless you really really have to.  A great way to foul up an environment.  And remember you have an esri version and not a full Anaconda installation
JoeBorgione
Yeah.  I'm just going through the shortcut mojo now. ...
JoeBorgione
Thanks Dan!  I have those bookmarked from the last time!
