Geocoding Script failing for Data on sde
6189
11
01-29-2016 01:10 PM
TiffanySelvidge1
I know this is a topic that has come up multiple times but I have gone through all the previous discussions and my geocoding is still failing. My script is from a modelbuilder I exported as python. I am using a composite geolocator with files that are updated daily. My table is from sql and is updated every 30 minutes.
I am using Arc 10.3.1, Python 2.7
Here is what I have already tried:
I have formatted my addresses to contain the exact address.
I have included overwrite = true.
I have changed SingleKey to Single Line Input and then just removed it completely.
I have changed the double quotes on Static to single quotes.
# Import arcpy module
import arcpy
#Overwrite pre-existing files
arcpy.env.overwriteOutput = True
# Local variables:
ArcDev_dbo_OIDTest_sites_2015i_2016_new = "C:\\Users\\tselvidge\\AppData\\Roaming\\ESRI\\Desktop10.3\\ArcCatalog\\[email protected]\\ArcDev.dbo.OIDTest_sites_2015i_2016_new"
  1. GISOWNER_ParcelAddrFacet_geo__2_ = "C:\\Users\\tselvidge\\AppData\\Roaming\\ESRI\\Desktop10.3\\ArcCatalog\\[email protected]\\ArcDEV.GISOWNER.ParcelAddrFacet_geo" ArcDev_GISOWNER_GeoRecs_New = "C:\\Users\\tselvidge\\AppData\\Roaming\\ESRI\\Desktop10.3\\ArcCatalog\\[email protected]\\ArcDev.GISOWNER.Sharept_symbolized\\ArcDev.GISOWNER.GeoRecs_New" ArcDev_GISOWNER_GeoRecs_New__3_ = ArcDev_GISOWNER_GeoRecs_New ArcDev_GISOWNER_GeoRecs_New__4_ = ArcDev_GISOWNER_GeoRecs_New__3_
# Process: Geocode Addresses
arcpy.GeocodeAddresses_geocoding(ArcDev_dbo_OIDTest_sites_2015i_2016_new, GISOWNER_ParcelAddrFacet_geo__2_, "'Single Line Input' AcctNo VISIBLE NONE;HCAD_NUM AcctNo VISIBLE NONE;Street Street VISIBLE NONE;City City VISIBLE NONE;State <None> VISIBLE NONE;ZIP ZIP VISIBLE NONE;QFNAME FileMapFacet VISIBLE NONE", ArcDev_GISOWNER_GeoRecs_New, 'STATIC')
TiffanySelvidge1
Bruce,
Thank you for your help!
It is now working from local and virtual server. I took out the space from "'single line input'" as you advised. When running from my local, I needed to use 'Database Connections' but on the virtual server I needed to use the entire path but without the r's. When I added r's the script became confused. I also had to change another parameter within the geocoding and modify the server connection from my personal login (admin) to gisowner login.
So it took a variety of modifications for each machine but at least it now works.
For now I am keeping the composite locator with the various locators. If it ends up breaking, I will change it. I am waiting since the workaround will be rather clumsy and significantly less efficient than what I currently have setup.
BruceHarold
Esri Frequent Contributor
Tiffany, use raw text notation for data like that, you have '\t' in the path, which is a tab when read.
i.e put 'r' ahead of your string:
r"C:\\Users\\tselvidge\\AppData\\Roaming\\ESRI\\Desktop10.3\\ArcCatalog\\[email protected]\\ArcDEV.GISOWNER.ParcelAddrFacet_geo"
TiffanySelvidge1
I put an 'r' in front but it still doesn't work.
BruceHarold
Sorry, another thing: the single like parameter is 'SingleLine', e.g.:
Executing: GeocodeAddresses HalfMoonBay "GIS Servers\arcgis on geocode.arcgis.com (user)\World.GeocodeServer" "SingleLine SingleLine VISIBLE NONE" C:\Users\bruc5588\Documents\ArcGIS\Projects\GeocodingDemo.gdb\Tiffany STATIC
TiffanySelvidge1
I made the change but I am still receiving the "ERROR 000010: Geocode addresses failed."
Here is the complete Traceback message:
  File "C:\Users\tselvidge\Documents\Dashboard\Scheduled_jobs\SharepointNewDataTest.py", line 25, in <module>
    arcpy.GeocodeAddresses_geocoding(ArcDev_dbo_OIDTest_sites_2015i_2016_new, GISOWNER_ParcelAddrFacet_geo__2_, "SingleLine AcctNo VISIBLE NONE;HCAD_NUM AcctNo VISIBLE NONE;Street Street VISIBLE NONE;City City VISIBLE NONE;State <None> VISIBLE NONE;ZIP ZIP VISIBLE NONE;QFNAME FileMapFacet VISIBLE NONE", ArcDev_GISOWNER_GeoRecs_New, 'STATIC')
  File "C:\Program Files (x86)\ArcGIS\Desktop10.3\ArcPy\arcpy\geocoding.py", line 212, in GeocodeAddresses
    raise e
ExecuteError: ERROR 000010: Geocode addresses failed.
Failed to execute (GeocodeAddresses).
BruceHarold
Tiffany I may have put you wrong earlier, I just did a single line input process and the input fields are stated like this:
in_address_fields="'Single Line Input' SingleLine VISIBLE NONE"
i.e. there should not be any more fields than just one, and the parameter is 'Single Line Input'.
Regards
TiffanySelvidge1
I am using a composite locator. If I can only list one field then how does it know to geocode based upon the other fields in the other locators?
BruceHarold
Tiffany, you cannot mix single and multi line handling in a composite locator.
TiffanySelvidge1
Interesting. I guess Python just can't handle it? Running the model in arcCatalog it works just fine.
BruceHarold
I just tried a composite with a field having the full address details (i.e single line) in a field I mapped to the ADDRESS input of a multiline run, and the other zone fields mapped normally, and I got the 000010 error, so its probably just data-dependent luck it works for you.
Messages
Executing: GeocodeAddresses D:\Work\Product_Management\LINZAddressing\lds-new-zealand-17layers-FGDB\StreetAddress.gdb\HalfMoonBay D:\Work\Product_Management\LINZAddressing\TestComposite "Address SingleLine VISIBLE NONE;Neighborhood <None> VISIBLE NONE;City SUBURB VISIBLE NONE;Subregion <None> VISIBLE NONE;Region MAILTOWN VISIBLE NONE;Postal POSTCODE VISIBLE NONE;PostalExt <None> VISIBLE NONE;CountryCode <None> VISIBLE NONE" D:\Work\Product_Management\LINZAddressing\lds-new-zealand-17layers-FGDB\StreetAddress.gdb\Geocode_Result STATIC
Start Time: Mon Feb 01 08:37:02 2016
Executing Geocode Addresses...
Failed at Mon Feb 01 08:37:07 2016 (Elapsed Time: 5.32 seconds)
