ftp download script
5007
8
10-26-2020 10:23 AM
TonyAlmeida
MVP Regular Contributor
I upgraded to 3.6 python and now I can't run my script that runs fine in 2.7, I am not sure why, any ideas?
current code
import arcpy
import os
import os.path
from ftplib import FTP
directory = "\\maps" #location of folder on ftp
copy_files = "*.pdf" # This is the files i would like to copy from the ftp site
folder = "D:\\temp\\temp\\"
out_path = os.path.join(folder)
#FTP logon
ftp = FTP("ftp.proper.com")
ftp.login('blahuser', 'blahpass')
# navigate folder
ftp.cwd(os.path.join(directory))
print ("Changed to " + os.path.join(directory, copy_files))
#Now get a list of all files in the folder
filenames = ftp.nlst()
print (filenames)
#and loop through the filenames to download the files to your local 'folder'
for f in filenames:
    with open(os.path.join(out_path, f), 'wb') as local_file:
        ftp.retrbinary('RETR '+ f, local_file.write)
ftp.close()
print ("closed ftp connection")
Error
  File "C:/Python Scripts/FPT/TransferFromFtp.py", line 15, in <module>
  File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\ftplib.py", line 420, in login
    resp = self.sendcmd('PASS ' + passwd)
  File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\ftplib.py", line 273, in sendcmd
    return self.getresp()
  File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\ftplib.py", line 246, in getresp
    raise error_perm(resp)
ftplib.error_perm: 530 Not logged in.‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
JoshuaBixby
MVP Esteemed Contributor
The error message is saying you aren't logged in.  Have the credentials possibly changed recently?
TonyAlmeida
Nope, I can ran that same script in 2.7 just fine. Then run it in 3.6 and gives me that error.
GeoJosh
Hi Tony,
I'm wondering if you need to keep the connection to the FTP open while you login, as demonstrated in the documentation for the ftplib module.
ftplib — FTP protocol client — Python 3.9.0 documentation
Something like this:
with FTP("ftp.proper.com"as ftp:
    ftp.login('blahuser''blahpass')
    # ... do more stuff
TonyAlmeida
Made the change and still gives me the same error
import arcpy
import os
import os.path
#FTP logon
with FTP("ftp.proper.com") as ftp:
    ftp.login("blahuser", "blahpass")
    # navigate folder
    print (filenames)
    for f in filenames:
    ftp.close()
DonShawEsri
Hi Tony,
I'd like to test the ftplib library in your Python 3 environment with an open FTP site to make sure that it can indeed connect to FTP sites. Does the login validate? Does the directory print?
ftp = FTP('ftp2.census.gov')
print(ftp.login())‍‍‍
print(ftp.dir())
TonyAlmeida
Yes it did.
230-Server: ftp2.census.gov
230-
230-Personal Identifiable Information (PII) shall not be placed on the FTP
230-server without prior special arrangement and in conjunction with ITSO.
230-
230-NOTE: The data available for anonymous FTP download on this FTP server are
230-also available over the Web:
230-http://www2.census.gov
230 Login successful.
TonyAlmeida
Not sure what happened but I re-started my pc and code ran fine. Not sure what held it up.
DonShawEsri
Chalk it up to being Monday... glad it worked!
