Finding an Average Rainfall Data
3337
11
05-02-2012 11:46 AM
RPatarasuk
Hi All,
I have about 350 files of PRISM rainfall data to process. I have e.g. precip from 1970 - 2010. and each year has 13 files.
ppt_1970.01.tif
ppt_1970.02.tif
ppt_1970.03.tif
ppt_1970.04.tif
ppt_1970.05.tif
ppt_1970.06.tif
ppt_1970.07.tif
ppt_1970.08.tif
ppt_1970.09.tif
ppt_1970.10.tif
ppt_1970.11.tif
ppt_1970.12.tif
ppt_1970.14.tif
ppt_2010.11.tif
ppt_2010.12.tif
ppt_2010.14.tif
I try to write a python code to calculate a long term average. Here is the code that I have so far. I have only tried to play around with 5-10 files and the program only returns values for the last file (i.e. it doesn't add up the values of previous file and find the average). Also, I would like to exclude "*.14" from the calculation.
# Import system modules
import arcpy
from arcpy import env
from arcpy.sa import *
# Check out the ArcGIS Spatial Analyst extension license
# Input data source
arcpy.env.workspace = "S:/Work/Risa/Trial & Error/input"
# Set output folder
OutputFolder = "S:/Work/Risa/Trial & Error/output/"
# Loop through a list of files in the workspace
rasterFiles = arcpy.ListRasters()
# Local variables:
for filename in rasterFiles:
    print("Processing: " + filename)
    inRaster = arcpy.env.workspace + "/" + filename
    outRaster = OutputFolder + "/" + "AvgPrecip.tif"
    #***need to process from all of the files except the ones that have "*.14"
    # Process: Cell Statistics
    arcpy.gp.CellStatistics_sa(inRaster, outRaster, "MEAN", "DATA")
print "***DONE!!!"
Any help would be very appreciated. Thank you very much.
Risa
DarrenWiens2
Haha, now that I look at it "*.14.tif" wouldn't work even if it used wildcards - there's an extra '.'
So, touché.
RPatarasuk
Dear philmorefield & dkwiens,
It works now. Thank you very much for your help.
if not filename.endswith("14.tif") -- this one works
if not filename.endswith("*.14.tif") -- this one, Phil is right, keeps looking for the "*" so the program keeps running non stop.
