Field Calculator - Dates using Python
1308
02-21-2011 07:40 PM
AndrewWise
Hi All,
I am trying to parse a string field into date field but having some issues with the ArcGIS field calculator.
Strings are in the format of:
being
I have tested my string parsing in the python console but for having some difficulty getting ArcGIS field calculator to accept it in the following format:
CodeBlock=
def MyFunction(nameInput):
  rasterParts = nameInput.split("_")
  newDate = datetime(int(rasterParts[1][0:4]), int(rasterParts[1][4:6]),int(rasterParts[1][6:8]),int(rasterParts[2][0:2]),int(rasterParts[2][2:4]) )
  return newDate
Expression=
MyFunction( !Name! )
It keeps coming back with:
Messages
ERROR 000539: Error running expression: MyFunction("idr02_20110203_0000_256.png")  <type 'exceptions.TypeError'>: 'module' object is not callable
Can anybody spot the error or have any alternative methods for parsing out the date?
Andrew
NiklasNorrthon
'module' object is not callable means that you are treating a module as a function.
datetime is a module
datetime(int(rasterParts[1][0:4]), ...) is trying to "call" the datetime module, instead of createing an object of type datetime.datetime.
AndrewWise
Thanks Niklas,
I knew it would be something simple. Adding the extra datetime.datetime reference worked fine.
Cheers
Andrew
