Field Calculator - Calculate string length using python syntax.
15503
10-25-2013 03:18 PM
BenFerguson
I'm trying to calculate the length of a string in the field calculator using Python syntax.  Normally this is done as len(stringValue).
The calculator shows a function .len()  My question is how is this intended to be used?  I can't seem to find the right syntax.
AnthonyGiles
Honored Contributor
Ben,
If the value is coming from a field then the field name needs to be contained in square brackets:
Len( [Field] )
Have a look at thus handy guide:
http://www.esri.com/news/arcuser/0405/files/fieldcalc_1.pdf
Regards
Anthony
RichardFairhurst
For Python use:
len(!FieldName!)
Brackets is only for VB Script.
