Fast way to delete row from table
1719
03-06-2012 02:49 PM
zhengniu1
hi, all
I am trying to delete row from file geodatabase table using following code:
import arcpy
import math
arcpy.env.workspace = r'C:\TempArcGISCalculate\Scratch.gdb'
intable="Section0011"
Statstbl="C:/TempArcGISCalculate/Scratch.gdb/S11FirstStats"
Query = '"FREQUENCY"=1'
records = arcpy.SearchCursor(Statstbl,Query)
singlelst = []
for record in records:
    singlelst.append(record.getValue('Trace')) # it adds data who has single point only
del records
del record
pts = arcpy.UpdateCursor(intable)
for pt in pts:
    for i in singlelst:
        if pt.Trace == int(i):
            print "Deleting:", pt.OBJECTID, pt.Trace
            pts.deleteRow(pt)
del pts, pt
In the table "Section0011", I have 534975 rows. When the script runs, it only remove about 1000 rows in couple hours, but has not finished yet. Is there any fast way to run deleteRow? please help
Thanks lot
MarcinGasior
In last part of the script try:
for pt in pts:
        if pt.Trace in singlelst:
instead of:
for pt in pts:
    for i in singlelst:
I simulated similar script situation with this code change and for feature class with over 550 000 rows, ~13 000 rows were deleted in less than 4 minutes.
MathewCoyle
Honored Contributor
Yes, I would implement Marcin's change. Your original script is running through every feature you want to delete for every row in your dataset. Uneconomical to say the least.
zhengniu1
Marcin and Mathew, Thank you so much
