Exporting Landscape and portrait maps using arpy.datadrivenpages
2371
01-20-2013 03:19 AM
DavidMcDermott
Dear GIS community,
I am very much a Python N00b so am in need to your expertise.
Scenario:
I am using data driven pages to export to PDF. Each PDF focuses on a single polygon (in this case a postal zone) along with the relative background map. Of the 18000 polygons, 8000 would best suite a Portrait layout and 10000 would be landscape. The orientation preference is already the the data driven pages index layer. The two mxd's are identical except for their layout.
My Aim:
I am trying to write a python script that would allow me to export a selection of polygons (either by a simple selection or a definition query), using the correct layout. I would be in one of the mxd's when running this script.
So far:
Here is the script I have so far -
# Import arcpy module
import arcpy
#Select Paramaters
Select_Index=arcpy.GetParameterAsText(0)
Select_Portrait_Layout = arcpy.GetParameterAsText(1)
Select_landscape_Layout = arcpy.GetParamterASText(2)
Export_Location = arcpy.GetParamaterAsText(3)
# Local variables:
Input_Feature = Select_Index
Output_Layer = "DDP_Index_Temp"
Select_Portrait_Layout = Select_Portrait_Layout
Select_Index = Select_Index
Select_landscape_Layout = Select_landscape_Layout
Export_Location = Export_Location
mxdport = arcpy.mapping.MapDocument(Select_Portrait_Layout)
mxdland = arcpy.mapping.MapDocument(Select_landscape_Layout)
# Process: Make Feature Layer
arcpy.MakeFeatureLayer_management(Input_Feature, Output_Layer, "", "", "OBJECTID OBJECTID VISIBLE NONE;Shape Shape VISIBLE NONE;NAME NAME VISIBLE NONE;AREA_CODE AREA_CODE VISIBLE NONE;DESCRIPTIO DESCRIPTIO VISIBLE NONE;FILE_NAME FILE_NAME VISIBLE NONE;NUMBER NUMBER VISIBLE NONE;NUMBER0 NUMBER0 VISIBLE NONE;POLYGON_ID POLYGON_ID VISIBLE NONE;UNIT_ID UNIT_ID VISIBLE NONE;CODE CODE VISIBLE NONE;HECTARES HECTARES VISIBLE NONE;AREA AREA VISIBLE NONE;TYPE_CODE TYPE_CODE VISIBLE NONE;DESCRIPT0 DESCRIPT0 VISIBLE NONE;TYPE_COD0 TYPE_COD0 VISIBLE NONE;DESCRIPT1 DESCRIPT1 VISIBLE NONE;Shape_Length Shape_Length VISIBLE NONE;Shape_Area Shape_Area VISIBLE NONE;Orientation Orientation VISIBLE NONE")
# Process: Select Portrait
arcpy.SelectLayerByAttribute_management(Output_Layer, "NEW_SELECTION", "\"Orientation\" = 'PORTRAIT'")
#Process: Export Portrait
mxdport.dataDrivenPages.exportToPDF(Export_Location,'SELECTED')
# Process: Select Landscape
arcpy.SelectLayerByAttribute_management(Output_Layer, "NEW_SELECTION", "\"Orientation\" = 'LANDSCAPE'")
#Process: Export Landscape
mxdland.dataDrivenPages.exportToPDF(Export_Location,'SELECTED')
The issue:
Simply put, it doesn't work. I keep getting the error the following error -
[ATTACH=CONFIG]20891[/ATTACH]
For this I am guessing its that i'm trying to export selected but from the wrong feature....??
help
David McDermott
JeffBarrette
Have you looked at this facing pages example.  The sample uses two different MXDs similar to what you are trying to do.
http://resources.arcgis.com/en/help/main/10.1/#/Creating_a_map_book_with_facing_pages/00s90000002p00...
Jeff
DavidMcDermott
Hi Jeff,
I used this example as a template for what I wrote. The difference is I want to select from attributes rather than the page number. The work flow would go as follows:
User
The user selects a group of features from the data driven pages index.
The Script
1. Create a temporary layer of the selection
2. From the temp layer, select [Orientation] = "LANDSCAPE"
3. Export Selected features to multiple PDF [page name] on the Landscape mxd
4. From the temp layer, select [Orientation] = "PORTRAIT"
5. Export Selected features to multiple PDF [page name] on the Portrait mxd
6. Delete temp layer.
I'm not sure of this is a flawed idea as I'm not sure if mapping.datadrivenpages recognizances the temporary feature layer as the input source.
