Export model to python
2763
06-26-2013 12:55 PM
kevinbrown1
Not sure if this is the best subforum, but nevertheless:
My "export script" feature in the toolbox has suddenly become grayed out Arc10.1. I can't figure out why.  Thanks!
RhettZufelt
MVP Notable Contributor
Could be a couple reasons.
One, if it is a python script that you are clicking on, there is no export option as it is already a .py file.  Can just choose "Edit" and will get the source.
If it is a model that you are clicking on, it will be greyed out as well.  however, if you click "Edit" on the model, then under the file menu, you should be able to export it.
R_
