Execute Python Script in SQL Server trigger
1482
11-02-2020 04:31 PM
DionO_Reilly
I have a python script that I need to run when a record is inserted into our SDE layer.  Anyone have success executing a python script from an Insert Trigger or have another suggestion?
nita14
I am afraid it is not supported. You need to try a regular SQL syntax to achieve this goal. Eventaully, if the updates go through REST API, you can try to develope Server Object Interception and implement the logic there.
BR,
Adam
