ESRI Pyhton Addin Assistant
2066
01-31-2014 06:02 AM
ScottShenberger
Good Morning
I created an Addin using the Addin Assistant using a python script and every time I run the script via the addin I created, ArcGIS crashes. I can reproduce it on another computer with the same results. I am not sure why this tool crashes ArcGIS. I can copy and paste the code into the python window and it runs just fine with no problems. My computer specs are: Win7 64bit Intel i7 32GB Ram ArcGIS 10.1 SP1
Scott Shenberger
GIS Analyst
Tucson Water
JasonScheirer
Esri Alum
Can you provide a copy of your add-in?
ScottShenberger
See attached
JasonScheirer
Esri Alum
I'm not seeing any sort of crash, just a failure when calling the TableToTable Tool:
  File "C:\...\AssemblyCache\{7E4CFC40-D898-41B3-8BBB-0B634DC2B183}\EsriAddin_addin.py", line 32, in onClick
    arcpy.TableToTable_conversion(NullServiceAddresses, Null_Services, "NullServiceAddresses.dbf", "", "ANCILLARYR \"ANCILLARYR\" true true false 2 Short 0 4 ,First,#,\\ADMIN.PotableNetwork\\ADMIN.Service,ANCILLARYROLE,-1,-1;ENABLED \"ENABLED\" true true true 2 Short 0 4 ,First,#,\\ADMIN.PotableNetwork\\ADMIN.Service,ENABLED,-1,-1;WSA \"WSA\" true true false 3 Text 0 0 ,First,#,\\ADMIN.PotableNetwork\\ADMIN.Service,WSA,-1,-1;SYNERGEN_I \"SYNERGEN_ID\" true true false 17 Text 0 0 ,First,#,\\ADMIN.PotableNetwork\\ADMIN.Service,SYNERGEN_ID,-1,-1;LIFECYCLES \"LifecycleStatus\" true true false 4 Text 0 0 ,First,#,\\ADMIN.PotableNetwork\\ADMIN.Service,LIFECYCLESTATUS,-1,-1;LASTEDITOR \"LASTEDITOR\" true true false 10 Text 0 0 ,First,#,\\ADMIN.PotableNetwork\\ADMIN.Service,LASTEDITOR,-1,-1;LASTEDITDA \"LASTEDITDA\" true true false 36 Date 0 0 ,First,#,\\ADMIN.PotableNetwork\\ADMIN.Service,LASTEDITDATE,-1,-1;LASTEDITSO \"LastEditSource\" true true false 4 Text 0 0 ,First,#,\\ADMIN.PotableNetwork\\ADMIN.Service,LASTEDITSOURCE,-1,-1;DOCUMENTNU \"DOCUMENTNU\" true true false 255 Text 0 0 ,First,#,\\ADMIN.PotableNetwork\\ADMIN.Service,DOCUMENTNUMBER,-1,-1;INSTALLYEA \"INSTALLYEAR\" true true false 2 Short 0 4 ,First,#,\\ADMIN.PotableNetwork\\ADMIN.Service,INSTALLYEAR,-1,-1;OWNERSHIP \"Ownership\" true true false 4 Text 0 0 ,First,#,\\ADMIN.PotableNetwork\\ADMIN.Service,OWNERSHIP,-1,-1;STREETDIR \"STREETDIR\" true true false 3 Text 0 0 ,First,#,\\ADMIN.PotableNetwork\\ADMIN.Service,STREETDIR,-1,-1;STREETNO \"STREETNO\" true true false 15 Text 0 0 ,First,#,\\ADMIN.PotableNetwork\\ADMIN.Service,STREETNO,-1,-1;STREETNAME \"STREETNAME\" true true false 50 Text 0 0 ,First,#,\\ADMIN.PotableNetwork\\ADMIN.Service,STREETNAME,-1,-1;SERVICESUB \"ServiceSubtype\" true true false 4 Long 0 5 ,First,#,\\ADMIN.PotableNetwork\\ADMIN.Service,SERVICESUBTYPE,-1,-1", "")
  File "c:\arcgis\arcpy\arcpy\conversion.py", line 2018, in TableToTable
    raise e
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000732: Input Rows: Dataset NullServiceAddresses does not exist or is not supported
Failed to execute (TableToTable).
Perhaps add some print statements in your onClick implementation to see how far the tool gets and where it crashes on your local machine?
ScottShenberger
It seems to crash at the field calculate. I have a dmp file if that helps.
JasonScheirer
Esri Alum
You may want to contact Esri support.
