Error when trying to publish geoprocessing service
5500
5
09-03-2013 12:51 PM
ionarawilson1
I am trying to publish a geoprocessing script from a script tool in python. The code runs great in ArcGIS but I am getting error messages when trying to publish the geoprocessing service.
[ATTACH=CONFIG]27179[/ATTACH]
#Import modules
import os, sys, arcpy, traceback, arcgisscripting
#Set Map Document
mxd = arcpy.mapping.MapDocument("Current")
#Set Overwrite Option
gp = arcgisscripting.create(10.1)
try:
    sCursor = arcpy.SearchCursor("Stewardship")
    for row in sCursor:
        if row.SequenceNumber:
            arcpy.AddError("You can't run the tool in previous records. Please select your last digitized record and run the tool")
        if not row.SequenceNumber:
        #Sets parameters (attributes)
            Status = gp.GetParameterAsText(0)
            Office =  gp.GetParameterAsText(1)
            Forester = gp.GetParameterAsText(2)
            DateStart = gp.GetParameterAsText(3)
            PlanLength = gp.GetParameter(4)
            PlanEQIP = gp.GetParameter(5)
        # Create domains
        # This is to send the code to the database but keep the description for the user input
            StatusDomain = {'Completed': 'C', 'Pending': 'P'}
            StatusCode = StatusDomain[Status]
            officeDomain = {'Alpine': 'AL', 'Austin': 'AU', 'Carthage': 'CA', 'Corpus Christi': 'CC''}
            officeCode= officeDomain[Office]
            foresterDomain = {'Brittany Compton': 'bcompton', 'Brian Pope': 'bpope' }
            foresterCode = foresterDomain[Forester]
            UnderservedDomain = {'Yes': '1', 'No': '0'}
            UnderservedCode = UnderservedDomain[Underserved]
    del row, sCursor
# This is to send the data input to the database
    with arcpy.da.UpdateCursor("Stewardship", ("Status", "Office", "Forester", "DateStart","PlanLength", "PlanEQIP", "RecipientLast", "RecipientFirst",
     "MailAddress", "City" , "State", "ZipCode", "Phone", "Email", "Underserved")) as rows:
        # row comes back as a tuple in the order specified here, so Office is row[0], Forester is row[1]
        for row in rows:
            row[0] = StatusCode
            row[1] = officeCode
            row[2] = foresterCode
            rows.updateRow(row)
    del row, rows
# This is to save only the year to the FFY field from the DateStart field
    with arcpy.da.UpdateCursor("Stewardship", ("FFY")) as rows:
        Datestarstr1 = str(DateStart)
        arcpy.AddMessage(Datestarstr1)
        if len(Datestarstr1) == 9:
            # if for example 6/28/2013 or 10/4/2013
                yearonly = DateStart[5:9]
        # if for example 6/8/2013
        if len(Datestarstr1) == 8:
                yearonly = DateStart[4:8]
        if len(Datestarstr1) > 9:
             # if for example 10/10/2013
                yearonly = DateStart[6:10]
                arcpy.AddMessage(yearonly)
                arcpy.AddMessage("TEST")
        for row in rows:
            row[0] = yearonly
            rows.updateRow(row)
# This is to create centroids of the stewardship boundaries to select the county that contains the centroid (stewardship), to be used to create the PlanID
    Countieslayer = 'Counties FL'  # this is a string that represents the Counties feature layer
    Stewardshiplayer = 'Stewardship FL'  # this is a string that represents the Stewardship feature layer
    Stewardshipcentroidslayer = 'Stewardship centroid FL'  # this is a string that represents the Stewardship feature layer
    if arcpy.Exists(Countieslayer):
        arcpy.Delete_management(Countieslayer)
        # make feature layer
    arcpy.MakeFeatureLayer_management("Counties", "Countieslayer")
    if arcpy.Exists(Stewardshiplayer):
        arcpy.Delete_management(Stewardshiplayer)
    arcpy.MakeFeatureLayer_management("Stewardship", "Stewardshiplayer")
    # I don't need to save the output to a folder, i can create a variable to hold a name and then create the layer after creating centroids
    outstewardshipcentroids = "StewardshipCentroids2"
    # Create centroid
    arcpy.FeatureToPoint_management("Stewardshiplayer",  outstewardshipcentroids,"INSIDE")
    if arcpy.Exists(Stewardshipcentroidslayer):
        arcpy.Delete_management(Stewardshipcentroidslayer)
    arcpy.MakeFeatureLayer_management(outstewardshipcentroids, "Stewardshipcentroidslayer")
    arcpy.SelectLayerByLocation_management("Countieslayer", "CONTAINS", "Stewardshipcentroidslayer", "", "NEW_SELECTION")
    countycode = tuple(arcpy.da.SearchCursor("Countieslayer", "FIPS_TXT"))[0][0]
    urows = arcpy.da.UpdateCursor("StewardshipLayer", "County")
    for urow in urows:
        urow[0] = countycode
        urows.updateRow(urow)
    del urows, urow
# To add 1 to the year if month starts in October
    import time
    from datetime import datetime, date
    #sim_date_counter = 1
    with arcpy.da.UpdateCursor("Stewardshiplayer", ("FFY")) as rows:
      for row in rows:
        #get the value of the date
        FFY = row[0]
        FFYnumber = int(FFY)
        #convert to string
        DateStartstr = str(DateStart)
        arcpy.AddMessage(DateStartstr)
        # Get only the month
        # To get only the first two characters:
        DateStart2 = DateStartstr[0:2]
        arcpy.AddMessage(DateStart2)
        if "/" in DateStart2:
                DateStart3 = DateStart[0:1]
                FFYnumbercount = FFYnumber
                arcpy.AddMessage(DateStart3)
                arcpy.AddMessage(FFYnumbercount)
        if "/" not in DateStart2:
            DateStart4 = int(DateStart2)
            FFYnumbercount = FFYnumber + 1
            arcpy.AddMessage(DateStart4)
        row[0] = str(FFYnumbercount)
        rows.updateRow(row)
# First we need to search by object id to it, it can be the highest, since there is only one selected
    #maxValue3 = arcpy.SearchCursor("Stewardshiplayer", "", "", "", "OBJECTID D").next().getValue("OBJECTID")
    trows = arcpy.SearchCursor("Stewardshiplayer")
    for row in trows:
               FFYtxt = row.getValue("FFY")
               Countytxt = row.getValue("County")
    arcpy.AddMessage("ffy:")
    arcpy.AddMessage(FFYtxt)
    del trows, row
# we list the layer to create a layer feature without a selection (because it is selected by the user)
    lyr = arcpy.mapping.ListLayers(arcpy.mapping.MapDocument('CURRENT'), 'Stewardship')[0]
    arcpy.MakeFeatureLayer_management(lyr.dataSource, "TMP")
# To get the total ammount of records, not only the selected
    result = int(arcpy.GetCount_management("TMP").getOutput(0))
# write a query to get the county and year using the FFY and County of the object id of the Stewardship layer (the one that is selected)
    query = "FFY" +"=" + "'"+ str(FFYtxt)+"'" + "AND " + "County" +"=" + "'"+ str(Countytxt)+"'"
    arcpy.AddMessage(query)
    # select all the records that have the FFYcounty the same as the FFYCounty of the hightest ObjectID
    arcpy.SelectLayerByAttribute_management("TMP",  "NEW_SELECTION", query )
# if there are more than 1 records with the same ffy and county
    # select only the record witht the highest sequencenumber (sort first, then select)
    if  result > 1:
        maxValue4 = arcpy.SearchCursor("TMP", "", "", "", "SequenceNumber D").next().getValue("SequenceNumber")
        query = "SequenceNumber = "
        arcpy.SelectLayerByAttribute_management("TMP",  "SUBSET_SELECTION", "SequenceNumber = " + str(maxValue4))
    rows = arcpy.SearchCursor("TMP")
    for row in rows:
               Seqnum = row.SequenceNumber
    del rows, row
# If the sequence number is equal or higher than 1 it means there are other records with the same FFY and County, so we add 1 to the number
    rows = arcpy.UpdateCursor("Stewardshiplayer")
# we make sure the Sequence number gets updated with the variable that is counting the sequence number
    for row in rows:
        row.Sequencenumber = Seqnum
    rows.updateRow(row)
    del rows, row
    with arcpy.da.UpdateCursor("Stewardshiplayer", ("Sequencenumber")) as rows:
        if Seqnum >= 1:
                arcpy.AddMessage("Other records with the same FFY and County")
                vsn = Seqnum + 1
        else:
                arcpy.AddMessage("No othe records with the same FFY and County")
                vsn = 1
        for row in rows:
           row[0] = vsn
           rows.updateRow(row)
# we Create the Plan ID concatenating the FFY, the county and the Sequence number, adding zeros in front of the sequence number if necessary to make the lenght always 3
    with arcpy.da.UpdateCursor("Stewardship", ("PlanID")) as rowsffycounty2:
        for row in rowsffycounty2:
            row[0] = str(FFYtxt) + "-" + str(Countytxt) + "-" + str(vsn).zfill(3)
            rowsffycounty2.updateRow(row)
except:
    tb = sys.exc_info()[2]
    tbinfo = traceback.format_tb(tb)[0]
    pymsg = "PYTHON ERRORS:\nTraceback Info:\n" + tbinfo + "\nError Info:\n     " +        str(sys.exc_type) + ": " + str(sys.exc_value) + "\n"
    msgs = "ARCPY ERRORS:\n" + arcpy.GetMessages(2) + "\n"
    arcpy.AddError(msgs)
    arcpy.AddError(pymsg)
    print msgs
    print pymsg
    arcpy.AddMessage(arcpy.GetMessages(1))
    print arcpy.GetMessages(1)
ionarawilson1
I fixed most errors by deleting the variables and assign names to the layers directly in the functions, I also added a path to the mxd document, instead of calling it "current". However, I still have one error:
Stewardshipcentroidslayer, used by Script Stewardship cannot be copied to the server.
Does anybody know why? Here is the code snippet:
    #Countieslayer = 'Counties FL'  # this is a string that represents the Counties feature layer
    #Stewardshiplayer = 'Stewardship FL'  # this is a string that represents the Stewardship feature layer
    #Stewardshipcentroidslayer = 'Stewardship centroid FL'  # this is a string that represents the Stewardship feature layer
    if arcpy.Exists("Countieslayer"):
        arcpy.Delete_management("Countieslayer")
    if arcpy.Exists("Stewardshiplayer"):
        arcpy.Delete_management("Stewardshiplayer")
    # Create centroid
    if arcpy.Exists("Stewardshipcentroidslayer"):
        arcpy.Delete_management("Stewardshipcentroidslayer")
ionarawilson1
I changed this line
to
    outstewardshipcentroids = "d:/ArcGISData/SARS/Temp/outstewardshipcentroids.shp"
And there are no more errors now
KevinHibma
Which version of Server are you using?
We fixed a lot of those issues in 10.2.
If you're using 10.2, I'm interested in getting your workflow to see if there are still issues that should be addressed.
thanks
ionarawilson1
Hi Kevin,
No, I am using 10.1. After publishing the geoprocessing service, I tried to run it and it failed. The log says:
Processing request took longer than the usage timeout for service 'GeoprocessingTests/Stewardship7.GPServer'. Server request timed out. Check that the usage timeout is appropriately configured for such requests.
Any ideas why? Thanks
KevinHibma
Do you have a very long running service? (like in Desktop it took a long time?)
The default setting for a GP Service is to be able to run for 10minutes (600 seconds) before the Server stops it.
Under the "Pooling" properties the service, you can increase "the maximum time a client can use a service".
http://resources.arcgis.com/en/help/main/10.2/#/Pooling_and_Processes/00570000007z000000/
