Error message in python
2377
9
12-17-2013 07:03 PM
minghuichua
Anyone here can help me solve this error that I encounter during my execution?
File "C:\Python27\Lib\site-packages\Pythonwin\pywin\framework\scriptutils.py", line 325, in RunScript
    exec codeObject in __main__.__dict__
  File "C:\Users\Administrator\Desktop\Minghui\Phyton\Testing.py", line 20, in <module>
    raw_new = compulsory + raw
TypeError: cannot concatenate 'str' and 'float' objects
Greatly appreciated.
Regards,
Minghui
DanPatterson_Retired
From the error message you appear to be trying to concatenate a string and a number.  I suspect "raw" is a number, hence it needs to be converted to a string using str(raw) prior to combining them
minghuichua
Thanks for the help. But I got another error asking me to define my Query_value1 when I've already define it. Below are the error message and part of my code.
Error message:
  File "C:\Users\Administrator\Desktop\Minghui\Phyton\Testing.py", line 25, in <module>
    for tags in Query_value1:
NameError: name 'Query_value1' is not defined
My code are below:
Query_value1 = fetcher.execute("select value1 from [Sheet2$]").fetchall()
tagname = []   #Tag name list with Bucket Brigade. prefix
for tags in Query_tag:
    raw = tags[-1]
    compulsory = 'Bucket Brigade.'
    raw_new = compulsory + str(raw)
    tagname.append(raw_new)
value1 = []  #1st column of data
    raw = tags[-1]
    value1.append(raw)
Regards,
Minghui
That is a new error...did this script ever work in stages? You might want to post what you are trying to do and a complete list of the error messages...I suspect your code isn't using "try...except" blocks so you can trap errors and their nature during execution
minghuichua
Currently I'm trying to send real-time data from excel spreadsheet to MatrikonOPC. I'm testing out with random data in excel sheet with my value 1 in the column B of the spreadsheet.
Below are my code:
import OpenOPCEdited
import pyodbc
import time
opc = OpenOPCEdited.client()
opc.connect('Matrikon.OPC.Simulation.1')
cnxn = pyodbc.connect('DSN=Excel Files;Dbq=C:\Users\Administrator\Desktop\Minghui\Testing.xlsm', autocommit=True)
fetcher = cnxn.cursor()
Query_tag = fetcher.execute("select tag from [Sheet2$]").fetchall()
    raw = tags[-1]
    raw = tags[-1]
    value1.append(raw)
interval = 60               # update interval in seconds
#Writing data to OPC
for iteration in range(2):
    n = 0
    m = n + 1
    for every in tagname:
        find_cb = every.find('CB')
        if find_cb == -1:
            opc[every] = value1
        if find_cb != -1:
            opc[every] = str(value1)
        n += 1
    time.sleep(interval)   #wait (X) seconds
Sorry for the trouble as I'm really a newbie in this stuff.
Regards,
Minghui
Insert your code in code blocks, it is largely unreadable since it lacks proper indentation etc
minghuichua
erm.. you mean insert in code block here? I've attach my code here too
No...code blocks is an html formatting code which you use to highlight your code on this forum.   Posting a *.py script just causes it to run (and fail) and people are less inclined to download...save...and debug code that could be viewed if properly documented and formatted on this site.  On an aside...this code is quite long...at what line did you first start getting error messages and are they all documented?
minghuichua
Cause this code was given to me by my professor in school.
Was able to execute previously by him. So I have to make amendment to it according to my excel spread sheet. But after making some amendment I'm not sure why the Query_value1 was not define when I did not change anything there. So I'm quite stuck at this stage
minghuichua
Hey thanks for the help. Somehow I manage to solve my problem and my data can be read into MatrikonOPC Explorer.
Do you know like what I need to include in order for python to auto update value in MatrikonOPC?
