Error in executing grid expression
2452
11-08-2011 04:49 AM
tomwaddington
Can any one help, explain and possible provide a solution as to why this code keeps producing and error. Everything else runs up to this point and every variable is defined.
gp.MultiOutputMapAlgebra_sa("H:\Internship_Tom_Waddington\New_code/forest_b2grd = CON('H:\Internship_Tom_Waddington\New_code/forest_b1grd > 0,H:\Internship_Tom_Waddington\New_code/dem_resample')")
  File "H:\Internship_Tom_Waddington\New_code\new_code.py", line 86, in <module>
ExecuteError: ERROR 010067: Error in executing grid expression.
Failed to execute (MultiOutputMapAlgebra).
RaphaelR
in python you have to specify paths in one of these 3 ways:
r"c:\path"
"c:\\path"
"c:/path"
using "c:\path" won´t work.
tomwaddington
Even with all the paths the same i.e. C:/path I still keep getting the Error in executing grid expression on the same line of code. Is there anything else that you think may be the cause?
DuncanHornby
MVP Notable Contributor
Tom,
Don't have a grid file name long than 8 characters.
Duncan
