error in arcpy sourcecode?
1081
01-29-2014 04:58 AM
BirteHegemann
Trying to create any Geometry object results in this message:
  File "C:\Data\Daten\Untersuchungsgebiete\FeatureClass ertstellen.py", line 15, in <module>
    Point=arcpy.Point ([row[1],row[3]])
File "C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcpy\arcobjects\mixins.py", line 1047, in __init__
    setattr(self, attr, value)
  File "C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcpy\arcobjects\_base.py", line 89, in _set
    return setattr(self._arc_object, attr_name, cval(val))
Any ideas whats going wrong?
Thanks a lot!
Regards,
Seschat
MichaelVolz
Esteemed Contributor
Are you running on a 64-bit OS?
Do you have other python scripts that run as expected?
You may be running the 64-bit python version which could be causing the issue.
NeilAyres
You are passing a list object into arcpy.Point :
Point=arcpy.Point([row[1],row[3]])
Take out the extra [], try :
Point=arcpy.Point(row[1],row[3])
assuming of course that row[1] & row[3] are both numeric.
Cheers,
Neil
