ERROR 000824: The tool is not licensed. Failed to execute (Near).
6552
02-07-2018 07:19 AM
JustinBridwell
I am running Esktop 10.5 and Python27. I have arcpy working fine from my IDE but
when I try to run the following, I get an error:
myNear = arcpy.Near_analysis(school_layer,tri_layer,"5000 meters")
The error says:
ExecuteError: Failed to execute. Parameters are not valid.
I tried looking this up in stack exchange, but the best that I could come up with is that 1) Either Near_analysis is part of some extension that requires an additional licnese/payment or 2) There is something incorrect about the parameters being used. Any ideas?
JakeSkinner
Esri Esteemed Contributor
Hi Justin,
The Near tool requires an ArcGIS Desktop Advanced license:
Near—Help | ArcGIS for Desktop
You may only have an ArcGIS Desktop Standard license.  You can check by going to Help > About ArcMap.  You will see the License Type there.
JakeSkinner
Hi Justin,
JustinBridwell
Yep. That's the issue. 😞
XanderBakker
You may want to have a look at a post by Dan Patterson‌: /blogs/dan_patterson/2017/01/23/generate-near-table-for-points  using numpy.
