Email from Python 2.7.x to 3.x
2638
08-27-2020 10:30 AM
Brian_McLeer
MVP Regular Contributor
In trying to migrate Python Scripts from ArcGIS Desktop Python 2.7.x to ArcGIS Pro 3.x, we email staff if there is a failure on a routine. Below I am running a sync replica routine using ArcGIS Pro, deliberately breaking it on the file path to the database connection string so it will email a failure. Somewhere in migration, it does not like the email code that has been working for years now. Has anyone else had to upgrade email failures from 2.7.x to 3.x in Python? With using the correct file path, the routine was successful. We use Windows Task Scheduler to run Python routines.
I receive the error (server name omitted for security):
try:
			arcpy.management.SynchronizeChanges(r"C:\Tech_Info\DB_CONX\SERVER\SERVER ParentDatabase user.sde", "ReplicaName", r"C:\Tech_Info\DB_CONX\Server\SERVER ChildDatabase user.sde", "FROM_GEODATABASE1_TO_2", "IN_FAVOR_OF_GDB1", "BY_OBJECT", "RECONCILE ")
except Exception as e:
			arcpy.AddMessage("SynchronizeChanges_management ISGIS.ReplicaName Failed..." +'\n')
			txtFile.write("SynchronizeChanges_management ISGIS.ReplicaName Failed..." +'\n')
			txtFile.write (arcpy.GetMessages() + '\n')
			HOST = "host.server.com"
			SUBJECT = "Priority: CRITICAL Routine Failure"
			TO = "[email protected]"
			FROM = "Routine Failure<[email protected]>"
			text = "Routine has failed. Please see log file for detailed information. \n Error Message: \n " + str(e.msg)
			BODY = string.join((
				"From: %s" % FROM,
				"To: %s" % TO,
				"Subject: %s" % SUBJECT,
				text
			), "\r\n")
			server = smtplib.SMTP(HOST)
			server.sendmail(FROM, [TO], BODY)
			server.quit()‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
by Anonymous User
Not applicable
Hi Brian McLeer‌,
Looking at the screen grab, it looks like the error is in the following line:
You are trying to call the "msg" of the exception.  You should be able to just call e to get the result you are after.
Also, using the "{}".format("") syntax for strings should clean up the code a little and will automatically convert things into the correct format.
Try this:
try:
   arcpy.AddMessage("SynchronizeChanges_management ISGIS.ReplicaName Failed...{0}".format('\n'))
   txtFile.write("SynchronizeChanges_management ISGIS.ReplicaName Failed...{0}".format('\n'))
   txtFile.write("{0}{1}".format(arcpy.GetMessages(), '\n'))
   text = "Routine has failed. Please see log file for detailed information. \n Error Message: \n {0}".format(e)
   BODY = "From: {1}{0}To: {2}{0}Subject: {3}{0}{0}{4}".format('\r\n', FROM, TO, SUBJECT, text)
   server.quit()
I hope this helps,
Michael
edit: Fixed up the indentation in the code block
by Anonymous User
Not applicable
Hi Brian McLeer‌,
Try this:
try:
   server.quit()
I hope this helps,
Michael
Brian_McLeer
Thank you, Michael, that did work. This will be helpful as we will have parallel Python environments of 2.7.x and 3.x until we can fully migrate to ArcGIS Pro.
DanDeegan
One thing you have to look forward to in python 3 are f strings. They are so helpful when trying to make sql expressions.
https://docs.python.org/3/reference/lexical_analysis.html#f-strings
