Does arcpy.mapping module allow you to run tools on layers within current mxd?
1176
07-08-2011 10:40 AM
CrystalCarreon
I am currently working on ArcMap v9.2 (I know...we are upgrading to 10 very soon) and I am having an issue running tools on layers within a current map document from a python script. For example, I want to use the select by attribute tool within a python script and have it display the selection within the current map document. Is this something I can do using the arcpy.mapping module or will I need to use VBA and/or vb.net?
Any help is much appreciated!
Crystal
TerrySilveus
use...
mxd = mapping.MapDocument('Current')
then everything done with mxd var will be for the Current map document
