Divide shp in about 20-50 adjacent polygons?
1406
10-09-2019 12:25 AM
JohannesBierer
I would like to divide a shp in about 20-50 adjacent polygons. I have the following script but the while loop (line 54) becomes endless if there are less than 10 adjacent polygons to select. Any ideas for a better solution?
# -*- coding: cp1252 -*-
import arcpy
arcpy.env.overwriteOutput = True
arcpy.env.workspace = "in_memory"
Alk_Sel = r"R:\Daten\sgb_Planungen\2013\Saalbachniederung\Eigentuemer\ALK_merge_E.shp"
alk_sel_Layer = "alk_sel_Layer"
InFile = r"C:\temp2\InFile.shp"
def SicFeature():
    arcpy.CopyFeatures_management(Alk_Sel, InFile)
    arcpy.MakeFeatureLayer_management(InFile, alk_sel_Layer)
def AddField():
    arcpy.AddField_management(alk_sel_Layer, "Round", "LONG")
def selectMin():
    sum = arcpy.GetCount_management(alk_sel_Layer)
    print sum
    i = 0
    for i in range(1, int(sum.getOutput(0)), 10):
        i += 1
        Expression = """ "Round" = {} """.format(0)
        arcpy.MakeFeatureLayer_management(InFile, alk_sel_Layer, Expression )
        sum1 = arcpy.GetCount_management(alk_sel_Layer)
        print('{} has a sum of {} records'.format(alk_sel_Layer, sum1[0]))
        MyList = list()
        cursor = arcpy.da.SearchCursor(alk_sel_Layer, "FID")
        for row in cursor:
            MyList.append(int(row[0]))
        print 'Minimum: {0}'.format(min(MyList))
        expression1 = min(MyList)
        arcpy.SelectLayerByAttribute_management(alk_sel_Layer, "NEW_SELECTION", """ "FID" = {} """.format(expression1))
        result1 = arcpy.GetCount_management(alk_sel_Layer)
        while (int(result1.getOutput(0)) < 10):
            arcpy.SelectLayerByLocation_management (alk_sel_Layer, "INTERSECT", alk_sel_Layer)
            print(result1)
        arcpy.CalculateField_management(alk_sel_Layer, "Round", i)
        OutFile = r"C:\temp2\OutFile_{}.shp".format(i)
        arcpy.CopyFeatures_management(alk_sel_Layer, OutFile)
SicFeature()
AddField()
selectMin()
JohannesBierer
            old_value = int(result1.getOutput(0))
            print(result1)
            if int(result1.getOutput(0)) == old_value:
                break‍‍‍‍‍‍‍‍‍‍‍
This was the solution for me.
NeilAyres
You generate a list of "i" in line 29, then in 31 you increment "i".
Then you only seem to use the value of "i" inside the while loop to identify the output.
Consider using 2 separate counters so you don't get confused and increment inside the while loop.
JohannesBierer
Thank you,
remains the question how to get out of the while loop if the result1 value didn't change.
JohannesBierer
            print(result1)
                break‍‍‍‍‍‍‍‍‍‍‍
