Detect broken links with arcpy?
10120
20
03-07-2014 10:59 AM
TracyDash
I adapted some code I found online to search for broken (moved or renamed) hyperlinks in a shapefile. It should write all broken links to a text file, but instead it is writing ALL the hyperlinks to the text file. Any advice on what to change? I know extremely little about python.
Also, I have arcmap 10.1
thank you!
import arcpy
import os
fc = r" C:\Users\GIS\Documents\TEST 2-25\project_test.shp"
fields = ["PROJECT_DW"]
with arcpy.da.SearchCursor (fc,fields) as cursor:
    for row in cursor:
        Roll = str(row[0])
        if os.path.exists(Roll):
            pass
        else:
            f = open(r"C:\Users\GIS\Documents\brokenlinks.txt","a")
            f.write(Roll + os.linesep)
            f.close()
TracyDash
Ahh yes I see. That's really too bad. I'll post if I ever find a solution.
But thanks for all your help! Much appreciated.
