deleting selected features (footprint shapes)
1498
6
03-07-2012 11:01 AM
MatthiasBuehler1
hi !
[ usually I am the person giving answers .. on CityEngine .. 🙂 ]
though I am new to Python coding in ArcGIS, so I'd be happy if anyone could help me with the following issue :
I have a layer with a few hundred shapes, where I am creating manual selections. based on those selected features, I'd like to delete n% of the selected shapes. e.g. 10% each time I run the script to 'thin out' the data in certain regions.
any input welcome .. !
MathewCoyle
Honored Contributor
Would you want these shapes randomly selected or would every 10th shape in the selection be fine?
MatthiasBuehler1
hey !
better randomly, but every nth would already be great.
I'm having the issue with actually getting the list from the selection..
MathewCoyle
Honored Contributor
This should get you started. Will delete every n row. The cursor will honour selections so just make sure you reference the feature layer you have the selection on.
import arcpy
flayer = #your feature layer with the selection, hardcode name or passed parameter
rows = arcpy.UpdateCursor(flayer)
count = 0
n = 10
for row in rows:
    count += 1
    if count == n:
        rows.deleteRow(row)
        count = 0
Deleting random rows while ensuring 10% is deleted is also possible, but would involve a bit more coding.
MatthiasBuehler1
hey !
thanks a lot for that code, it works so far !
to understand what actually happens here is that all features are actually stored as they were in a geometrical grid and then you delete them based on that grid ?
is it also possible to just use a for loop and (possibly) delete each object based on a probability ? or are list based structures not possible ?
thx again so far !
ChrisSnyder
Honored Contributor
This code should give you a random 10% sample of the OBJECTIDs in a feature layer that have a selected set.
#Warning: Untested
import random, arcpy
samplePct = 0.1
arcpy.MakeFeatureLayer_managment(roadsFC, "roads", "")
arcpy.SelectLayerByAttribute_managment("roads", "NEW_SELECTION", "ROAD_TYPE = 'Highway')
fidSetList = [int(fid) for fid in arcpy.Describe("roads").fidSet.split(";")]
if len(fidSetList) * samplePct >= 1: #error check rto make sure you have enough selected features to get an appropriate sample
   randomSampleList = radom.sample(fidSetList, int(len(fidSetList) *samplePct))
else:
   print "Not enough selected features to constitute a " + str(samplePct * 100) +  "% sample!"
Then you could delete them like this:
arcpy.MakeFeatureLayer(roadsFC, "delete_me", "OBJECTID in (" + str(randomSampleList)[1:-1] + ")")
arcpy.DeleteFeatures_Managment("delete_me")
or use an update cursor... same thing.
MatthiasBuehler1
hi Chris !
thanks for that input ! appreciated.
I'll have a look at this.
matt
