Deleting double quotation " in field, find/replace errors - script
8257
14
01-12-2011 01:01 PM
TurnerNowak
I have several shape files (all Parcels.shp) that I run scripts on in an attempt to clean and standardize the address field (SIT_FULL_S).  Whenever a record has a double quotation, I get an error and the script shuts down.
Here is what I am using:
gp.CalculateField_management(fc + "\\Parcels.shp", "SIT_FULL_S", "!SIT_FULL_S!.replace(u'\u0022',u'\u0027')", "PYTHON", "")
example 1 - Script works with this text:          125 South  Main Street
example 2 - Script shuts down with this text:  125 South "Main Street"
When I try example 1, the scripts runs.
When I try example 2, the script quits with Error 000539
Long story short, how can I remove any occurances of " from my field so that I can run my address scrubbing scripts ?
Or perhaps I should ask how to modify my below script to ignore the " and continue running. Here is an example of one of my address scrubbing scripts and the log showing the error:
gp.CalculateField_management(fc + "\\Parcels.shp","SIT_FULL_S", "!SIT_FULL_S!.lstrip('0')", "PYTHON")
arcgisscripting.ExecuteError: ERROR 000539: Error running expression: "9030 W SR 2 HWY "A"".lstrip('0') <type 'exceptions.SyntaxError'>: invalid syntax (<string>, line 1)
Failed to execute (CalculateField).
by Anonymous User
Not applicable
Couple of things.  One method I use for this is...
gp.CalculateField_management(fc + "\\Parcels.shp", '"%s" % (!SIT_FULL_S!.replace('"','')'), "PYTHON", "")
Regarding the code and your error.  The 999999 is very generic.
Looking at this code, I don't see how it could possibly work as intended.
Why are you looping through all the objects in ListWorkspaces() and then doing rows = gp.UpdateCursor("//Parcels.shp")?  Aren't you just reopening the same shape file?
Couldn't you just do?
for row in rows:
    row.name = row.GetValue("Name").replace("-", "")
    rows.updateRow(row)
del row
del rows
import arcgisscripting
import logging
logger = logging.getLogger()
gp = arcgisscripting.create(9.3)
gp.OverWriteOutput = True
gp.Workspace = "C:\ZP4"
fcs = gp.ListWorkspaces("*","Folder")
for fc in fcs:
    print fc
    row = rows.Next()
    while row:
        dash = string.find(name, "-")
        if dash != -1:
            fix = name.replace("-", "")
    del row, rows
TurnerNowak
Thanks for the suggestions Huey.
When I try your calculate field script I get this:
C:\Documents and Settings\Andrew>"C:\Python24\New Text Document.py"
  File "C:\Python24\New Text Document.py", line 19
SyntaxError: invalid syntax
And when I try your update cursor script I get this:
C:\Documents and Settings\Andrew>"C:\Python24\update cursor test.py"
C:\ZP4\TEST2
  File "C:\Python24\update cursor test.py", line 15, in <module>
    for row in rows:
TypeError: 'geoprocessing cursor object' object is not iterable
LoganPugh
The "for row in rows" syntax was introduced with arcpy in ArcGIS 10. For 9.3 and earlier you'll need to use the following construct:
row = rows.Next()
while row:
   <do stuff>
   row = rows.Next()
del row, rows
TurnerNowak
Thanks lpugh01 , I made those changes and modified a few other lines to come up with a script that works.
Here is what I have now :
import logging
for fc in fcs:
    print fc
    rows = gp.UpdateCursor(fc + "//Parcels.shp")
    row = rows.Next()
    while row:
        Name = row.GetValue('APN').replace('"', '')
        print Name
        row.SetValue('Apn', Name)
        rows.updateRow(row)
        row = rows.Next()
    del row
    del rows
PaulBrandt
From the code suggestions in this thread (credit all who shared) I put together a model tool that you can use straight up with python code blocks to calculate fields when you have double quotes in a field.
