delete rows in feature classes where some of the fields contain zero (0)
7123
5
02-05-2015 05:42 AM
ErtTre
So far I got this far:
import arcpy
from arcpy import env
env.workspace = r"C:\SouthA\Bolivia.gdb"
listFCs = arcpy.ListFeatureClasses("*")
for fc in listFCs:
     rows = arcpy.UpdateCursor(fc, , , ["field1", "field2", "field6", "field7"])
     for row in rows:
          if row.getValue() == 0:
          rows.deleteRow(row)
The idea is that in each table select and delete the rows which have "0"s in either/or  field1, field2....
Ert
JoshuaBixby
MVP Esteemed Contributor
For starters, I encourage you to read up on the Arcpy Data Access module (arcpy.da).  The cursors in the data access module are newer, more robust, and higher performing than the older cursors.
I gotta step out but will post some code when I get back if someone hasn't already.
JoshuaBixby
Haven't tested, but try:
import arcpy
for fc in listFCs:
    with arcpy.da.UpdateCursor(fc, ["field1", "field2", "field6", "field7"]) as cur:
        for row in cur:
            if 0 in row:
                cur.deleteRow()
BlakeTerhune
Instead of checking each row to see if it meets the condition, could you only bring back the rows that meet the condition and delete them all?
import arcpy
arcpy.env.workspace = r"C:\SouthA\Bolivia.gdb"
field_names = ["field1", "field2", "field6", "field7"]
where_clause = "field1 = 0 OR field2 = 0 OR field6 = 0 OR field7 = 0"
for fc in listFCs:
    with arcpy.da.UpdateCursor(fc, field_names, where_clause) as cur:
        for row in cur:
            cur.deleteRow()
JoshuaBixby
That is another approach.  Although I like working with SQL, building SQL expressions via Python and passing them to Esri tools seems to be a hang up for lots of folks, so I decided against suggesting a where_clause, but it will work.
ErtTre
Thanks Guys,
Both ideas worked!
