Delete or clean existing UN data from SDE before exporting new Data using Python
448
05-14-2026 07:58 PM
Ashok
I am working on a requirement that I need to export Electric UN data from one sde (stag environment) to another sde (client specific) using Python. And its a daily basis task, so I need to run this script daily at sometime using Task scheduler.
As part of this process, I divided whole script into 2 scripts.
Script 1 blocks new connections, disconnects users, finds the utility network in the target geodatabase, deletes the utility network, then deletes the remaining feature datasets, feature classes, and tables in the target workspace. - Having Issue
Script 2 Deletes the existing xml from folder. Export the source SDE UN data as xml workspace. Imports the xml workspace at target SDE - Working
Script 1 when I run manually from ArcGIS Pro python window, sometimes working as expected and sometimes not.
My Script1 code is below
import arcpy
import os
import sys
import traceback
import datetime
import time
import gc
from contextlib import suppress
# INPUTS
target_sde = r"C:\Export\ExportUN_08052026\SQLServer-svrwp-oms-gis_sqlexpress-DBmigration(gismigrationuser).sde"
admin_sde = r"C:\Export\ExportUN_08052026\SQLServer-svrwp-oms-gis_sqlexpress-DBmigration(gisadmin).sde"
log_file = r"C:\Export\ExportUN_08052026\UNReplica.log"
# LOGGING
def log(msg):
    timestamp = datetime.datetime.now().strftime("%Y-%m-%d %H:%M:%S")
    message = f"[{timestamp}] {msg}"
    print(message)
    with open(log_file, "a", encoding="utf-8") as f:
        f.write(message + "\n")
# HELPERS
def clear_cache(ws=None):
    with suppress(Exception):
        if ws:
            arcpy.management.ClearWorkspaceCache(ws)
        else:
            arcpy.management.ClearWorkspaceCache()
def force_release():
    try:
        arcpy.env.workspace = None
        gc.collect()
        clear_cache()
        time.sleep(5)
    except:
        pass
# VALIDATE WORKSPACE
def validate_workspace(workspace, retries=5):
    for attempt in range(1, retries + 1):
        try:
            force_release()
            arcpy.env.workspace = workspace
            datasets = arcpy.ListDatasets("*", "Feature") or []
            desc = arcpy.Describe(workspace)
            log(
                f"Workspace validation attempt {attempt} - datatype: {desc.dataType}"
            if desc.dataType == "Workspace":
                log(f"Workspace datasets: {datasets}")
                return True
        except Exception as ex:
            log(f"Workspace validation failed: {ex}")
        # Sometimes SDE becomes File temporarily
        try:
            log("Temporarily enabling connections")
            arcpy.AcceptConnections(admin_sde, True)
            time.sleep(10)
            log("Blocking connections again")
            arcpy.AcceptConnections(admin_sde, False)
            time.sleep(10)
            log(f"Connection reset failed: {ex}")
    return False
# LIST USERS
def list_users():
    try:
        users = arcpy.ListUsers(admin_sde)
        if not users:
            log("No connected users found")
            return []
        log("Current connected users:")
        for user in users:
            try:
                log(
                    f"User={user.Name}, "
                    f"Client={user.ClientName}, "
                    f"Connected={user.ConnectionTime}"
            except:
                pass
        return users
        log(f"Failed listing users: {ex}")
        return []
# DISCONNECT USERS
def disconnect_users():
    users = list_users()
    protected_users = ["dbo", "gisadmin"]
    for user in users:
        try:
            user_name = getattr(user, "Name", "").lower()
            if user_name in protected_users:
                log(f"Skipping protected user: {user_name}")
                continue
            log(f"Disconnecting user: {user_name}")
            arcpy.DisconnectUser(admin_sde, user.ID)
            log(f"Failed disconnecting user: {ex}")
    time.sleep(5)
    # Verify remaining users
    log("Verifying remaining users/locks")
    remaining = arcpy.ListUsers(admin_sde)
    if remaining:
        for user in remaining:
            try:
                log(f"Remaining user: {user.Name}")
            except:
                pass
    else:
        log("No remaining users")
# FIND UTILITY NETWORK
def find_un(workspace):
    try:
        if hasattr(desc, "children"):
            for child in desc.children:
                try:
                    if getattr(child, "dataType", "") == "FeatureDataset":
                        if "UtilityNetwork" in child.name:
                            log(
                                f"Utility Network found inside {child.catalogPath}"
                            return child.catalogPath
                except:
                    pass
        return None
        log(f"Failed finding utility network: {ex}")
        return None
# DELETE WITH RETRY
def delete_with_retry(path, label, retries=5):
        try:
            force_release()
            log(f"Deleting {label}: {path}")
            arcpy.management.Delete(path)
            log(f"{label} deleted successfully")
            return True
            log(
                f"Delete attempt {attempt} failed for {label}: {ex}"
            time.sleep(10)
    return False
# CLEANUP
def cleanup_target():
    # USE ONLY ADMIN CONNECTION
    log("Initializing ADMIN workspace connection")
    arcpy.env.workspace = admin_sde
    if not validate_workspace(admin_sde):
        raise Exception(
            "Target SDE connection is not a valid Workspace."
    # BLOCK CONNECTIONS
    log("Blocking new connections")
    # DISCONNECT USERS
    disconnect_users()
    # VALIDATE AGAIN
        raise Exception(
            "Target workspace became invalid after blocking connections."
    # DELETE UN
    un_path = find_un(admin_sde)
    if un_path:
        log(f"Preparing to delete Utility Network Dataset: {un_path}")
        success = delete_with_retry(
            un_path,
            "Utility Network Dataset"
        if not success:
            raise Exception(
                "Failed deleting Utility Network Dataset after retries."
    else:
        log("Utility Network dataset not found")
    # DELETE FEATURE DATASETS
    for ds in datasets:
        path = os.path.join(admin_sde, ds)
        delete_with_retry(path, "Feature Dataset")
    # DELETE FEATURE CLASSES
    fcs = arcpy.ListFeatureClasses() or []
    for fc in fcs:
        path = os.path.join(admin_sde, fc)
        delete_with_retry(path, "Feature Class")
    # DELETE TABLES
    tables = arcpy.ListTables() or []
    for tbl in tables:
        path = os.path.join(admin_sde, tbl)
        delete_with_retry(path, "Table")
    log("Target cleanup completed")
# MAIN
try:
    start = datetime.datetime.now()
    log("====================================")
    log("UTILITY NETWORK CLEANUP")
    cleanup_target()
    duration = datetime.datetime.now() - start
    log(f"Process completed in {duration}")
except Exception as e:
    log("ERROR OCCURRED")
    log(str(e))
    log(traceback.format_exc())
    sys.exit(1)
finally:
    try:
        log("Connections re-enabled")
        log(f"Failed to re-enable connections: {ex}")
    log("Script finished")
And my log is here. data is not getting cleaned.
[2026-05-14 04:00:05] ====================================
[2026-05-14 04:00:05] UTILITY NETWORK CLEANUP
[2026-05-14 04:00:05] Initializing ADMIN workspace connection
[2026-05-14 04:00:15] Workspace validation attempt 1 - datatype: Workspace
[2026-05-14 04:00:15] Workspace datasets: ['GISMIGRATIONUSER.UtilityNetwork', 'GISMIGRATIONUSER.ElectricDataset']
[2026-05-14 04:00:15] Blocking new connections
[2026-05-14 04:00:15] Current connected users:
[2026-05-14 04:00:15] User=DBO, Client=SVRWP-GIS4:13.5.5.57366, Connected=2026-05-14 04:00:13
[2026-05-14 04:00:15] Skipping protected user: dbo
[2026-05-14 04:00:20] Verifying remaining users/locks
[2026-05-14 04:00:20] Remaining user: DBO
[2026-05-14 04:00:27] Workspace validation attempt 1 - datatype: Workspace
[2026-05-14 04:00:27] Workspace datasets: ['GISMIGRATIONUSER.UtilityNetwork', 'GISMIGRATIONUSER.ElectricDataset'].
Kindly help me in resolving this issue.
Ashok
