del cur error ????
7111
7
02-06-2015 02:24 PM
DEAF_PROBERT_68
Honored Contributor
This is what I wrote from the book Programming ArcGIS 10.1 with Python Cookbook wrote by Eric Pimper and it is on Chapter 7th.
#Script to Import data to a feature class within a geodatabase
import arcpy, os
arcpy.env.workspace = "C:/ArcpyBook/data/Wildfires/WildlandFires.mdb"
f = open("C:/ArcpyBook/data/Wildfires/NorthAmericaWildfires_2007275.txt", "r")
try:
    # the output feature class name
    outputFC = arcpy.GetParameterAsText(0)
    # the template feature class that defines the attribute schema
    fClassTemplate = arcpy.GetParameterAsText(1)
    #Open the file to read
    f = open(arcpy.GetParameterAsText(2), 'r')
    arcpy.CreateFeatureclass_management(os.path.split(outputFC)[0], os.path(outputFC)[1]), "point", (fClassTemplate)
    lstFires = f.readlines()
    cur = arcpy.InsertCursor(outputFC)
    cntr = 1
    for fire in lstFires:
        if 'Latitude' in fire:
            continue
        vals = fire.split(",")
        latitude = float(vals[0])
        longitude = float(vals[1])
        confid = int(vals[2])
        pnt = arcpy.Point(longitude, latitude)
        feat = cur.newRow()
        feat.shape = pnt
        feat.setValue("CONFIDENCEVALUE", confid)
        cur.insertRow(feat)
        arcpy.AddMessage("Record number" + str(cntr) + "written to feature class")
        cntr = cntr + 1
except:
    print arcpy.GetMessages()
finally:
    del cur
    f.close()
The error showed here
  File "C:\ArcpyBook\Ch7\InsertWildfires.py", line 34, in <module>
    del cur
NameError: name 'cur' is not defined
DEAF_PROBERT_68
Honored Contributor
Okay I finally figured it out !  Apparently the book on Chapter 7 has some errors in it as I was trying to work on them in Pyscripter and Python Window and got it worked ! This HAS nothing to do with the del cur I had to re-read the instructions and found that the chapter mention to delete two hardcoded THAT should be include in the python script !    phew !
This is the correct coding.
import arcpy, os
cur = arcpy.InsertCursor("FireIncidents")
try:
    arcpy.CreateFeatureclass_management(os.path.split(outputFC)[0],os.path.split(outputFC)[1],"POINT", fClassTemplate)
    cntr = 1
            continue
        feat = cur.newRow()
        feat.shape = pnt
        cur.insertRow(feat)
        arcpy.AddMessage("Record number " + str(cntr) + "written to feature class")
        cntr = cntr + 1
except:
finally:
    del cur
    f.close()
DanPatterson_Retired
I suspect it is already gone... whenever you run a script through an IDE, you can inspect its variables using
locals().keys()     (or globals or vars .keys() )
to see what namespace remains after a script is run and what has been delete is what is in your script and these values
DEAF_PROBERT_68
Honored Contributor
Where do I find this information in an IDE ? Would Pyscripter show the avaiable variable to replace the cur ?
you can run the samples I posted in PyScripter in the interactive section
DEAF_PROBERT_68
Honored Contributor
Thank you. That is what I thought so. Does that mean ESRI took out the cur sytanx ? Ok, I will look into that as what you suggest. I have googled it as well but did not find it. I tried cursor and it came back an error...
Here is an example....  before a script is run...a script is run with no namespace deletion...then the namespace that remains after
You can get real fancy and do set differences etc etc if you want.
>>> a = set(locals().keys())
>>> a = list(set(locals().keys()))
>>> a.sort()
>>> a
['__builtins__', '__doc__', '__name__', '__package__', 'a', 'pywin']
>>> # now run a script....
Running...C:\!Scripts\Cursors\cursor_functions.py
Spatial Reference NAD_1983_CSRS_MTM_9
>>> b = list(set(locals().keys()))
>>> b.sort()
>>> a
>>> b
['SR', 'SR_PCSCode', '__builtins__', '__doc__', '__name__', '__package__', 'a', 'arcpy', 'desc', 'find_overlaps', 'input_shp', 'move', 'os', 'poly_pnts', 'pywin', 'sys']
JoshuaBixby
MVP Esteemed Contributor
Robert, if you could use Syntax highlighting in the advanced editor, it would make reading and discussing your code easier for commenters.
You are getting that error because of the del cur statement in the finally section of your code.  In Python error handling, the finally clause is always executed before exiting the try statement, even if there was an error.  In your case, you had an error either while creating the cursor object or before, and the cursor object was never instantiated.  Since it wasn't instantiated, it can't be deleted in the finally clause.
Looking at the code, you should have received another error message before the del cur error.  What other messages did you receive?
DEAF_PROBERT_68
Honored Contributor
import arcpy, os
try:
    cntr = 1
            continue
        feat = cur.newRow()
        feat.shape = pnt
        cur.insertRow(feat)
        cntr = cntr + 1
except:
finally:
    del cur
    f.close()
