Data Management Tools/Geodatabase Administration/ Compress tool in Python
2622
12-12-2013 09:09 AM
HectorChapa
Under Systems toolboxes/Data Management Tools/Geodatabase Administration/Compress tool. Is there a way to recreate this tool in python so it can compress the geodatabase enterprise every week. Any help in finding this in arcpy.
would the following script be the python for this tool
import arcpy
arcpy.Compress_management("Database Connections\Connection to brockville.sde")
JakeSkinner
Esri Esteemed Contributor
WilliamCraft
You could do this in Python, but you really don't have to.  Another route to go would be to set up a Windows batch file with SDE command line and run it as a scheduled task; then have it email you the results.  For example, try something like this (assumes Oracle but you could modify for SQL Server):
sqlplus sde/sde@database @c:\scripts\lineages_report.sql
sdeversion -o compress -i esri_production -u sde -p sde -N
c:\scripts\rnetmail -t [email protected] -f SDE@servername -s Nightly Compress Report -m c:\scripts\lineages_report.txt -x smtp.domain.int
Lines 1 and 3 run a separate SQL script against the database to grab the current state ID for BEFORE and AFTER the compress and then spit those numbers out to a text file.  Line 2 performs the compress.  Line 4 would be where you'd send the email containing the info from the text file; in this example I'm showing the use of a utility called RNETMAIL but there are plenty of options for this.  We follow a procedure like this and, each night after the compress finishes, we get an email showing us how much the lineage got crunched.  One thing to remember, however, is that the SDE command line tools will eventually be deprecated after the next release of ArcGIS.
collindegueurce
This is something I am a little confused on...
Don't you actually need to also reconcile/post outstanding edits and then delete user versions -> compress -> recreate user versions -> update statistics
I have been looking for a python script that will actually do this full compress workflow but so far have only found pieces.
Any insight to this would be appreciated!
collindegueurce
Actually William Craft you already answered the question at the link below.
https://community.esri.com/message/86698#86698
Just found that. Thanks!
