Data Driven Pages - to PNG using ArcPy
3772
01-04-2017 12:41 PM
CamW
Hello,
I am using ArcPy to export data driven pages to PNGs. I need the export to have a higher resolution then the default one when you export your map using ArcPy.
This is the script that I am using
mxd = arcpy.mapping.MapDocument("CURRENT")
for pageNum in range(1, mxd.dataDrivenPages.pageCount + 1):
mxd.dataDrivenPages.currentPageID = pageNum
pageName = str(mxd.dataDrivenPages.pageRow.New_ID)
arcpy.mapping.ExportToPNG(mxd, r"C:\Users\" + pageName + ".png")
del mxd
I want the resolution to be 200.
Where would I add this into the script?
DarrenWiens2
There is a resolution parameter: ExportToPNG—Help | ArcGIS Desktop
CamW
Thank you. Now where does it fit into the script?
DarrenWiens2
On each help page related to arcpy (e.g. arcpy functions, classes, or geoprocessing tools) the Python syntax for the "thing" is near the bottom. In this case, it says:
ExportToPNG (map_document, out_png, {data_frame}, {df_export_width}, {df_export_height}, {resolution}, {world_file}, {color_mode}, {background_color}, {transparent_color}, {interlaced})
I don't want to be too cryptic, but you need to do some of the work here.
FC_Basson
Adding to Darren's comment, just change the export line to:
arcpy.mapping.ExportToPNG(mxd, r"C:\Users\" + pageName + ".png", resolution=200)
