Data Driven Pages: Python code to include page index in output file name?
1794
11-19-2013 12:24 PM
by Anonymous User
Not applicable
I have used the DDP toolbar to set up DDP where 'Reach' is the index layer (as in river reach).  Each of the 100 Reaches has an ID, stored in the attribute table.  I want the output JPG name to be Reach ID plus _reachmap.jpg, concatenated.  However, instead of Reach ID I am getting a number between 1 and 100.  I have tried replacing pageNum with various other things but I get the same results or an error.  How can I get DDP to 'see' the Reach ID instead of the generic 1 to 100?
import arcpy mxd = arcpy.mapping.MapDocument("CURRENT") for pageNum in range(1, mxd.dataDrivenPages.pageCount + 1):     mxd.dataDrivenPages.currentPageID = pageNum     arcpy.mapping.ExportToJPEG(mxd, r"C:\output\\" + str(pageNum) + "_reachmap.jpg") del mxd
JasonScheirer
Esri Alum
Using the pageRow property.
So something like arcpy.mapping.ExportToJPEG(mxd, r"C:\output\\" + str(mxd.dataDrivenPages.pageRow.Reach_ID) + "_reachmap.jpg")
JasonScheirer
Esri Alum
by Anonymous User
Not applicable
Exactly like that!  I was messing around with getPageIDFromName and getting nowhere.  Thanks much!
MathewCoyle
Honored Contributor
Something like this should work if you are referring to your ddp index field value. If it isn't your index field then just insert the name of the field instead of ddp.pageNameField.name
import arcpy
ddp = mxd.dataDrivenPages
for pageNum in range(1, ddp.pageCount + 1):
    id_val = ddp.pageRow.getValue(ddp.pageNameField.name)
    arcpy.mapping.ExportToJPEG(mxd, r"C:\output\{0}_reachmap.jpg".format(id_val))
del mxd
by Anonymous User
Not applicable
import arcpy
del mxd
Looks good!  I will try both of these options as I build-out my script.  Thanks!
