da.InsertCursor super slow
2252
5
03-11-2025 04:51 PM
RandyBonds_Jr_
I have the following code that will take around 12 Hours in insert 7,000 rows. I have no idea why it is so slow.
the routeRunRows is just a dictionary from an oracle database (cursor.fetchAll() using the oracledb library). When I run the loop without the arcpy.da.InsertCursor it take seconds (which makes sense). Any help would be appreciated.
for row in routeRunRows:
    if (x%1000) == 0:
        message = str(x) + ' Processed...'; show_py_message()
    x += 1
    with arcpy.da.InsertCursor("d:/projects/SolidWaste/SolidWaste.sde/SolidWaste.DBO.cayServiceOrders", ["RouteNumber","RouteDescription","StartDate","RouteOrder","StreetAddress","ServiceItemType","SerialNumber","X","Y","ItemUse","RouteNote","AccountNumber","AccountStatus","ServiceItemID","SHAPE@XY"]) as insertSO:
        routeNote = " "
        if row[10] is not None:
            routeNote = row[10][:120]
        insertSO.insertRow((row[0],row[1],row[2],row[3],row[4],row[5],row[6],row[7],row[8],row[9],routeNote,row[11],row[12],row[13],(row[7],row[8])))
DavidPike
MVP Notable Contributor
It's extremely likely the cause is instantiating the cursor for each key in the dictionary, that's an expensive operation each time.
Simply instantiate the cursor once, and have the dictionary iteration below/within the cursor.
fc = "d:/projects/SolidWaste/SolidWaste.sde/SolidWaste.DBO.cayServiceOrders"
with arcpy.da.InsertCursor(fc, [
    "RouteNumber", "RouteDescription", "StartDate", "RouteOrder",
    "StreetAddress", "ServiceItemType", "SerialNumber", "X", "Y",
    "ItemUse", "RouteNote", "AccountNumber", "AccountStatus",
    "ServiceItemID", "SHAPE@XY"
]) as insertSO:
    x = 0
        if (x % 1000) == 0:
            message = f"{x} Processed..."
            show_py_message()
        x += 1
        routeNote = row[10][:120] if row[10] else " "
        # Insert row
            row[0], row[1], row[2], row[3], row[4], row[5], row[6],
            row[7], row[8], row[9], routeNote, row[11], row[12],
            row[13], (row[7], row[8])
DavidPike
]) as insertSO:
    x = 0
        if (x % 1000) == 0:
            show_py_message()
        x += 1
        # Insert row
RandyBonds_Jr_
I'll give that a try. I'm curious if you could explain why that makes a difference? Isn't it just a string?
RandyBonds_Jr_
Never mind, I read that wrong. I see what you're talking about. Thanks!
DavidPike
Ah ok haha that's good.  I'll add my thinking anyway, but I could be wrong.
1.  Every cursor establishes a new data connection.  This can be painful depending on where your data resides e.g. if it's in an SDE over VPN etc.
2.  Data schema is read and validated every time, again and again.  Nowhere near as bad as point number 1, but it's not exactly going to make things faster.
RandyBonds_Jr_
Final update on this thing. Thanks A TON! The script now runs in 10 seconds!
