Custom packages wtih 64-bit processing
1350
05-31-2013 07:22 AM
ShaneBuscher
I have a 2008R2 server with both ArcGIS Desktop 10.1 (with Background Geoprocessing) and ArcServer 10.1 installed.  I've developed a custom Python package that I deploy to C:\Python27\ArcGISx6410.1\Lib\site-packages.  I also created a PYTHONPATH environment variable pointing to this same directory.  Finally, I added C:\Python27\ArcGISx6410.1 to my PATH environment variable.
Previous to yesterday I could test my Python package within ArcMap, which is consumed through a Python Toolbox.  For reasons unknown to me, I started getting exceptions.  I boiled the problem all the way down to not even being able to 'import arcpy' within ArcMap's Python interpreter.  I was getting the exception:
>>> import arcpy
Runtime error
  File "<string>", line 1, in <module>
  File "D:\Python27\ArcGISx6410.1\Lib\site-packages\numpy\core\__init__.py", line 5, in <module>
    import multiarray
ImportError: DLL load failed: %1 is not a valid Win32 application.
That's pretty serious when you can't even import arcpy within ArcMap.  Long story short, I ended up having to remove the PYTHONPATH environment variable to import arcpy successfully.  However, when I tried to run my custom tools within ArcMap exceptions were still being thrown. On a whim I copied my Python package into the 32-bit site-packages directory (C:\Python27\ArcGISx6410.1\Lib\site-packages), which got everything running again.
While I did find solutions to the issues, I'm unclear about what caused the problem in the first place? Furthermore, I'm very unclear on why I had to deploy my package for 32-bit, as ArcMap should be using 64 bit (I have background GP turned on).
Would life be easier if I deployed my Python package somewhere other than C:\Python27\ArcGISxxx  and then set the PYTHONPATH to that directory?  Any best practices?
Regards,
Shane
ShaneBuscher
I ended up moving my Python package out of C:\Python27\ArcGISx6410.1\Lib\site-packages and into D:\geoprocessing, then set my PYTHONPATH to search the new location.  Still not sure what sparked the problem though.
LucasDanzinger
Esri Frequent Contributor
This isn't terribly helpful, as there doesn't seem to be a completely clear solution, but here's a similar thread- http://forums.arcgis.com/threads/79087-Problem-importing-arcpy-in-ArcMap-console-64-bit-DLL-conflict
ShaneBuscher
