CSV to feature class
8227
12
02-06-2020 01:14 PM
jaykapalczynski
Honored Contributor
I have a csv file in a folder location that gets updated every hour.
I need to take this info and update a Feature Class that is being published to a feature service.
Looking for the smartest and most effective means in which to do this.
Stored Procedure and then to FC?  Any ideas would be appreciated.
BruceHarold
Esri Frequent Contributor
The ETL approach requires Data Interoperability extension and the ability to author the processing, but we have big sites taking this no-code approach to maintaining hosted feature services from arbitrary source data on a regular schedule, so it works.
JoeBorgione
Not knowing how the points are published, I would think if it is to a local on-prem portal that then is an AGOL item , updates including truncates and append should be invisible to the end users, no?
EricShreve
This is a script that created in Jupyter Notebook and exported as a Python Script that runs on a server once a day. It parses a website that builds a nice data frame/CSV that then appends to a point feature service. Line 134 should work for your workflow. Hope that helps.
#!/usr/bin/env python
# coding: utf-8
# In[42]:
import bs4 as bs
import urllib.request
import pandas as pd
import numpy as np
from arcgis.gis import GIS
from arcgis import features
from copy import deepcopy
import arcpy
# In[43]:
source = urllib.request.urlopen('https://smoke.azdeq.gov/').read()
soup = bs.BeautifulSoup(source,'lxml')
# In[44]:
table = soup.table
# In[45]:
table = soup.find('table')
# In[46]:
table_rows = table.find_all('tr')
# In[47]:
for tr in table_rows:
    td = tr.find_all('td')
    row = [i.text for i in td]
    print(row)
# In[48]:
dfs = pd.read_html('https://smoke.azdeq.gov/',header=0)
for df in dfs:
    print(df)
# In[49]:
df.head()
# In[50]:
df['Location'] = df['Location']                          .astype(str).str.replace(r"[\(\)']", '')
# In[51]:
lat = []
lon = []
# In[52]:
# For each row in a varible,
for row in df['Location']:
    # Try to,
    try:
        # Split the row by comma and append
        # everything before the comma to lat
        lat.append(row.split(',')[0])
        # everything after the comma to lon
        lon.append(row.split(',')[1])
    # But if you get an error
    except:
        # append a missing value to lat
        lat.append(np.NaN)
        # append a missing value to lon
        lon.append(np.NaN)
# In[53]:
# Create two new columns from lat and lon
df['latitude'] = lat
df['longitude'] = lon
# In[54]:
df['latitude'] = df['latitude'].apply(lambda x: ' '.join(x.split(' ')[1:]))
# In[55]:
del df['Location']
# In[56]:
df.head()
# In[57]:
df.to_csv(r'C:\Code\Python\Web_Scraping\ADEQ_RX_Burns\CSV\ADEQ_RX_Burns1.csv', encoding='utf-8', index=False)
# In[63]:
gis = GIS("https://www.arcgis.com", "Your Username", "Your Password")
print("Logged in as " + str(gis.properties.user.username))
# In[64]:
arcpy.management.XYTableToPoint(r"C:\Code\Python\Web_Scraping\ADEQ_RX_Burns\CSV\ADEQ_RX_Burns1.csv", r"C:\Code\Python\Web_Scraping\ADEQ_RX_Burns\New File Geodatabase.gdb\ADEQ_RX_Burns1", "longitude", "latitude", None, "GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]];-400 -400 1000000000;-100000 10000;-100000 10000;8.98315284119521E-09;0.001;0.001;IsHighPrecision")
# In[65]:
arcpy.management.CalculateField(r"C:\Code\Python\Web_Scraping\ADEQ_RX_Burns\New File Geodatabase.gdb\ADEQ_RX_Burns1", "Ignition_Date", "datetime.datetime.now()", "PYTHON3", '', "TEXT")
# In[66]:
arcpy.management.Append(r"'C:\Code\Python\Web_Scraping\ADEQ_RX_Burns\New File Geodatabase.gdb\ADEQ_RX_Burns1'", "https://services6.arcgis.com/l7uujk4hHifqabRB/arcgis/rest/services/ADEQ_RX_Burns1/FeatureServer/0", "NO_TEST", r'Smoke_Unit_Number "Smoke Unit Number" true true false 2147483647 Text 0 0,First,#,C:\Code\Python\Web_Scraping\ADEQ_RX_Burns\New File Geodatabase.gdb\ADEQ_RX_Burns1,Smoke_Unit_Number,0,5000;Burn_Number "Burn Number" true true false 2147483647 Text 0 0,First,#,C:\Code\Python\Web_Scraping\ADEQ_RX_Burns\New File Geodatabase.gdb\ADEQ_RX_Burns1,Burn_Number,0,5000;Burn_Name "Burn Name" true true false 2147483647 Text 0 0,First,#,C:\Code\Python\Web_Scraping\ADEQ_RX_Burns\New File Geodatabase.gdb\ADEQ_RX_Burns1,Burn_Name,0,5000;Ignition_Date "Ignition Date" true true false 8 Date 0 0,First,#,C:\Code\Python\Web_Scraping\ADEQ_RX_Burns\New File Geodatabase.gdb\ADEQ_RX_Burns1,Ignition_Date,-1,-1;Approved_Acres "Approved Acres" true true false 0 Long 0 0,First,#,C:\Code\Python\Web_Scraping\ADEQ_RX_Burns\New File Geodatabase.gdb\ADEQ_RX_Burns1,Approved_Acres,-1,-1;Notes "Notes" true true false 2147483647 Text 0 0,First,#,C:\Code\Python\Web_Scraping\ADEQ_RX_Burns\New File Geodatabase.gdb\ADEQ_RX_Burns1,Notes,0,5000;latitude "latitude" true true false 0 Double 0 0,First,#,C:\Code\Python\Web_Scraping\ADEQ_RX_Burns\New File Geodatabase.gdb\ADEQ_RX_Burns1,latitude,-1,-1;longitude "longitude" true true false 0 Double 0 0,First,#,C:\Code\Python\Web_Scraping\ADEQ_RX_Burns\New File Geodatabase.gdb\ADEQ_RX_Burns1,longitude,-1,-1', '', '')
# In[67]:
arcpy.management.Delete(r"'C:\Code\Python\Web_Scraping\ADEQ_RX_Burns\New File Geodatabase.gdb\ADEQ_RX_Burns1'", '')
# In[ ]:
