Creating a list of tuples from arcpy.ListFields()
2662
06-02-2020 11:27 AM
JoeBorgione
I'd like to create a list of tuples where each tuple contains the data from the fields of one feature class: the objective is to iterate through the list and add fields of the name, type and length provided in each of the tuples to a different feature class.  I've hit a snag and I'm sure how to un-snag myself:
fc = r'C:\path\to_gdb\featureClass'
fieldList = []
for f in arcpy.ListFields(fc):
    x = (f'("{f.name}","{f.type}",{f.length})')
    fieldList.append(x‍‍‍‍‍‍‍‍)‍‍‍‍
works pretty good, but not quite perfect.  Each of the tuples is bounded by single quotes so if I try to use the tuple indexes to extract a tuple element, things head south:
fieldList
Out[79]:
['("OBJECTID","OID",4)',
 '("SHAPE","Geometry",0)',
 '("siteaddid","String",20)',
 '("addressptid","String",20)',
 '("rclnguid","String",254)',
 '("discrpagid","String",75)',
 '("preaddrnum","String",5)',
 '("addrnumsuf","String",5)',
I can cheat (and I have) and just copied and pasted fieldList to notepad and deleted the single quotes, but that's using a hammer; how would I create a clean list of tuples without the bounding single quotes:
cleanList
Out[82]:
[('OBJECTID', 'OID', 4),
 ('SHAPE', 'Geometry', 0),
 ('siteaddid', 'String', 20),
 ('addressptid', 'String', 20),
 ('rclnguid', 'String', 254),
 ('discrpagid', 'String', 75),
 ('preaddrnum', 'String', 5),
 ('addrnumsuf', 'String', 5),
That should just about do it....
JoshuaBixby
MVP Esteemed Contributor
Why are you building a string representation of a tuple:
instead of just building a tuple:
x = (f.name,f.type,f.length)
JoshuaBixby
DanPatterson
F (orget) the f-strings.  Remember they are always going to produce a string output.
... sort of retired...
JoeBorgione
Typical Joe blunder.  That's why I needed a couple extra set of eyes....
