Create geodatabase on desktop SDE
9706
10
05-18-2015 12:14 PM
PaulKroseman
Does anyone have a script or know which geoprocessing tool to reference to create a geodatabase on the desktop version of SDE? (10.3)
FreddieGibson
Honored Contributor
Yea....I'm pretty sure we don't have any out-of-the-box tools or scripts that would allow you to do this outside of the GUI for personal sde.
AlexanderNohe1
Honored Contributor
I believe that you are looking for the following help documentation:
Create Enterprise Geodatase (Data management)
Create Enterprise Geodatabase—Help | ArcGIS for Desktop
PaulKroseman
I was thinking that but I could not find the authorization file to input. Where do you find the authorization file for the desktop install?
FreddieGibson
Honored Contributor
You should see a keycodes file in a path similar to C:\Program Files\ESRI\License10.3\sysgen. This would be on a machine with ArcGIS Server installed.
PaulKroseman
I am using the SQL express database that comes with the Desktop package (Database_Server_Desktop_103_143531.exe). I can create geodatabases using the GUI as shown in the attachments without an authorization file. I wanted to script this process.
JoshuaBixby
MVP Esteemed Contributor
Paul Kroseman​, you are interested in Personal/Desktop SDE, right?  The links being provided are for Enterprise SDE or enterprise geodatabases.  Personal SDE or desktop geodatabases don't require additional keycodes like workgroup geodatabases and enterprise geodatabases.  If you are interested in desktop geodatabases, check out Database Server (Desktop) installation guide.  I don't think setting up desktop geodatabases is as scriptable as enterprise geodatabases, but I haven't looked into it completely.
PaulKroseman
Yes, I am looking at the Personal/Desktop SDE. I have it setup and working but I would like to script the creation of geodatabases. I find it odd that scripting would not be supported or requires an ArcGIS Server license.
FreddieGibson
Honored Contributor
FreddieGibson
Honored Contributor
PaulKroseman
Freddie Gibson wrote:
Yea....I'm pretty sure we have any out-of-the-box tools or scripts that would allow you to do this outside of the GUI for personal sde.
I'm sure you meant "we don't have any".
