Create Feature Class (Data Management): Optional Parameters
4392
03-03-2015 08:31 PM
MatthiasBuehler
In this link:
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
Some additional parameters like e.g. the template are defined. How do I use these additional parameters ?
If I want to use only one of the additional parameters, is this possible ? Or do I need to add ALL the same parameters if I use any at all because of the number of parameters the method accepts is fixed?
Any input welcome.
M.
ModyBuchbinder
Hi
You can give the parameter name equal the value if you do not want to give empty quotes or # for missing parameter.
Check the AddField example here:  ArcGIS Help 10.2 - Understanding tool syntax
Have fun
Mody
ModyBuchbinder
Hi
Have fun
Mody
MatthiasBuehler
aha! I think I get it ..
thank helps a lot. I will try it out!
thank you!
matt
