Create cloned conda environment as user
17808
18
06-14-2017 12:55 PM
curtvprice
I am not allowed admin access, but I really want to be able to use pro's Conda environment. Currently my only option is to run another Conda install, but in theory, can't I clone the Pro environment to a folder have access to?
Conda suggests this:
Error: Missing write permissions in: C:\ArcGIS\Pro\bin\Python
# You don't appear to have the necessary permissions to update packages
# into the install area 'C:\ArcGIS\Pro\bin\Python'.
# However you can clone this environment into your home directory and
# then make changes to it.
# This may be done using the command:
# $ conda create -n my_arcgispro-py3 --clone=C:\ArcGIS\Pro\bin\Python\envs\arcgispro-py3
but if I try it I get an error message:
PermissionError: [WinError 5] Access is denied: 'C:\\ArcGIS\\Pro\\bin\\Python\\nvs\\my_arcgispro-py3'
Is this possible?
Tags (1)
TobiasLitherland
Ok, great! That worked.
Thank you very much, Clinton Dow. You have been ever so helpful.
GIS_Spellblade
Has the creation of new environments been address yet in Pro?
ClintonDow1
Yes, new environments will now go to the user's AppData/Esri/conda directory which should allow them to interact with it and not experience permission issues.
curtvprice
Is this the case for per-user installs of ArcGIS Pro? Or admin installs too?
PhilLarkin1
Any update? It doesn't appear supported in 2.2
ClintonDow1
You should now be able to clone environments in 2.2 via the Manage Environments dialog by selecting an environment and clicking the clone button to the right hand side.
PhilLarkin1
Thanks for your reply.
Is it possible to clone the acrgis pro environment outside of the Pro root directory? For production level processes/analysis it is risky to rely on code in user folders. It is actually impossible most cases for me to run after hours processes and have access to my user folder.
HåkonDreyer
This is possible using conda from the Python Command Prompt. From there you may clone environments to your chosen location.
conda create --clone arcgispro-py3 --prefix c:\mydir\myclone
note that if you put your environment outside the defined envs directories they will not be listed using
conda info --envs
But you may still activate the environment, and all conda functionality are available, but you must use full path to the environment. Set active:
activate c:\mydir\myclone
Or just reference the clone with a full path when running conda commands:
conda install --name c:\mydir\myclone flask
NB: At the moment you may hit the issue described here https://community.esri.com/thread/217048-arcgis-pro-220-and-python-package-manager?sr=inbox&ru=15937... but I guess there will be a fix out soon.
PhilLarkin1
Thanks for your help. I was able to clone an environment outside of the pro directory and import arcpy from python from that env.
I think I'll wait for Pro 2.2.1. While I can't recreate the bug at 2.2 I'd rather not risk it.
