Count of fields in a row that satisfy a query
7573
8
01-27-2017 02:50 PM
TessOldemeyer
I am wanting to calculate the count of fields in a row where designated fields in a feature class attribute table satisfy a query (in this case, where the value is greater than 0) and then write the count (sum) of the number of fields that satisfy this query into a new field.
This seems simple, but I am having a hard time wrapping my head around how to do this using SQL or Python. Any suggestions or advice would be much appreciated.
Thanks in advance!
Tags (4)
RandyBurton
You could use the field calculator and something like:
def FieldCount(fld1,fld2, ...):
  fields = [fld1, fld2, ...] # field values to list
  return sum(f > 0 for f in fields)
FieldCount( !F01!, !F02!, ... )‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Or this for the function:
 return sum(v > 0 for k, v in locals().iteritems())‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Also look at Joshua Bixby‌'s answer in this thread.
IanMurray
Honored Contributor
Have you looked at using cursors to pull the values of each value of each field you need in a row to check see if it is greater than 0?
https://pro.arcgis.com/en/pro-app/arcpy/data-access/updatecursor-class.htm
BlakeTerhune
In Python, Joshua Bixby‌ covers the options in this blog post.
In SQL, you can do something like
select count(*) from TableName where FieldName > 0
EDIT:
Just to clarify your question, I will edit it for what I think you meant to say...
I am wanting to calculate the count of rows in a field where designated fields in a feature class attribute table satisfy a query (in this case, where the value is greater than 0) and then write the count (sum) of the number of rows that satisfy this query into a new field.
IanMurray
Honored Contributor
Thanks for the link, adding to my bookmarks.
TessOldemeyer
Nope, I meant the count of fields per row (per feature) where designated fields satisfy a query. Here I am looking for the the count of fields (this would only pertain to 5 of the 40 fields in the feature class) which have a value greater than zero. I would also then like to write the count (sum) of the number of fields that satisfy this query into a new field, so this new field would have a count of 0 (or NULL) or an integer from 1 to 5.
Does this help? I apologize for the lack of clarity. Thanks for the help! I would also like to eventually integrate this into a Python script (eventually).
BlakeTerhune
Some sample data would help. I think I understand but it is a very unusual request and I want to make sure.
TessOldemeyer
I  was looking to get the sum of the number of particular fields in a row that had a value greater than zero (to find how many of these unique attributes each feature had, e.g. ). I think Randy hit on exactly what I was looking for. Thanks a bunch!
RandyBurton
TessOldemeyer
Thank you so much. This is exactly what I was looking for! Works great!
