Copying only text from a string field to a new field
7729
14
07-19-2012 02:22 AM
PieterSnyders
Good day,
I know this is probably a stupid question. I am working with a river data set and the labeling field is a string field containing text (river names) and integer (river codes). I want to copy only the text (river names) to a new field. How can I do this with the field calculator... any help will be appreciated.
Regards,
P
JakeSkinner
Esri Esteemed Contributor
You will want to specify the field that has the current values in the update() function.  So, change:
 update(!Label_Field!)
to:
update(!TAG!)
This will calculate the values, that begin with a character, from the TAG field to the LABEL_FIELD.
PieterSnyders
Success! Thank you! Now I will just have to figure out exactly how this works lol
PieterSnyders
Funny enough two numerical values remained: 92 and 9390553
JakeSkinner
That was my mistake, the code should have been:
def update(field):
  if field[0] in str(range(0, 10)) or field[0] == '#':
    pass
  else:
    return field
What this code is doing is checking the first character of each value.  If the first character is a number within the range of 0 - 10, or if the character is a '#' sign it will pass this row.  If the character is a letter, it will update the row in the new field with that value.
PieterSnyders
Thank you for the explanation, will speed up my work! Really need to learn more of this very handy!
