Copy Tables or Features Classes changes fieldnames that exceeds length of 28?!
1093
02-25-2014 11:43 PM
gismoe
Since 10.0 SP4 (until 10.1 SP1) i can't use arcpy.CopyRows_management or arcpy.CopyFeatures_management
with fieldnames that exceeds 28 characters.
These fieldname were change. Here some examples:
aaaaaaaaaaaaaaaaaaaaaaaaaa28     aaaaaaaaaaaaaaaaaaaaaaaaaa28         everything OK
aaaaaaaaaaaaaaaaaaaaaaaaaaa29    aaaaaaaaaaaaaaaaaaaaaaaaaaa2_20      wrong name
aaaaaaaaaaaaaaaaaaaaaaaaaaaa30   aaaaaaaaaaaaaaaaaaaaaaaaaaaa_21      wrong name
aaaaaaaaaaaaaaaaaaaaaaaaaaaaa31  aaaaaaaaaaaaaaaaaaaaaaaaaaaaa_22            wrong name
The number after the underscore seems to be the field-id.
FGDB to FGDB works but FGDB to ArcSDE (on SQL Server) doesn't!
Copy the data with ArcCatalog works.
Is this a known bug?
Is there a workaround or patch?
