Copy FeatureClass
2053
6
04-30-2014 04:49 AM
MickeyO_Neil
Hello,
i want to copy a FeatureClass which is in a Feature-Dataset into an other Feature-Class (which is also in a Feature-Dataset).Both Feature-Classes are on different SDEs.
arcpy.Copy_management(fromgdbpath + "\\" + fd + "\\" + fc,  togdbpath + "\\" + toschema + "." + outfd+ "\\" + toschema + "." + outfc, "FeatureClass")
I always get the following error:
('ERROR 000258: Output C:\\...<Path>... already exists\nFailed to execute (Copy).\n',)
Of course the Output-FC already exists, but why is this a Problem? If I use the Copy-Geoprocessintool in ArcCatalog with the same Parameters everything works fine!
And if i copy Feature-Classes into other Feature-Classes which are not in a Feature-Dataset, it works, too.
Thanks for your help!
Cheers Mickey
Zeke
Honored Contributor
You don't want Copy, you want Append or Merge. Copy makes a new feature class, and you already have the destination feature class. If you want to replace the destination, delete the destination first and use copy, or delete features and append.
MickeyO_Neil
But the Copy-Tool also copys the Indexes and my target FC is empty, so copy would be just fine.
Zeke
Honored Contributor
Do the feature classes have the same name? Do they have different spatial references? Either will cause the tool to fail.
MickeyO_Neil
It works on ArcGIS 10.1 when I use this Line of Code:
arcpy.env.overwriteOutput = True
But when I want to run the same Script on an ArcGIS 10.2.1, the same ERROR shows up!
How is that possible? It's the same code?
Even the Place where I copy to, is the same ArcSDE in my local Network!
MichaelVolz
Esteemed Contributor
Is this an error that just appeared when you upgraded from v10.1 to v10.2?
MickeyO_Neil
No, these are two different machines. No upgrad was made.
My final solution:
I split my script in two parts:
If I'm allowed to delete a FeatureClass I use:
if arcpy.Exists(__toFCpath):
   arcpy.Delete_management(__toFCpath)
arcpy.Copy_management(__fromFCpath, __toFCpath)
And if i'm not allowed to delete a FeatureClass I use:
arcpy.DeleteRows_management(...)
arcpy.Append_management(...)
and
arcpy.AddIndex_management(...)
to copy the Indexes.
But be aware of Bug NIM084818 if you are using ArcGIS 10.2.0 or lower:
The Append geoprocessing tool fails to append field values for fields with field names that have 29 or more characters.
Cheers.
Mickey
