ConvertWebMapToMapDocument function renaming the data frames
4133
04-14-2015 06:16 AM
ionarawilson
If the ConvertWebMapToMapDocument function renames the active dataframe in the template mxd  to "Webmap", what does it rename the other data frame, the inactive one? Thanks
Tags (1)
ionarawilson
I found that when you convert to Map Document it only converts the active data frame.
